New Product Coming
DAYS
HRS
MINS
SECS
5 Best DJ Wireless Microphones in 2024
The equipment used by DJs has undergone significant changes over the years – among the most important changes is the implementation of wireless devices. The introduction of wireless microphones has revolutionized the way DJs operate, providing them with more freedom and flexibility during performances. However, choosing the best DJ wireless microphone can be overwhelming because there are several technical factors to consider to ensure you make the right choice. Some of the most important factors are:
  • The range of the microphone: A good wireless microphone must have a wide range to capture all the nuances of your voice without distortions or interferences.
  • Battery life: It is essential for DJs who perform for extended periods. Also, rechargeable batteries deteriorate with use, meaning the batteries must be high-quality to avoid having to change mics often. Finally, there are also charging periods – they shouldn’t take too long to charge fully!
  • Sensitivity and sound/noise suppression: A sensitive microphone can pick up even the slightest sound, ensuring that your audience can hear every word you say. But if it also captures the noise around you, what’s the point?
  • The frequency range of the microphone: Since DJs play at venues that usually have more than one wireless mic, it’s important to have a microphone that has a wide range of frequencies to pick from. Other features related to this such as automatically connecting the strongest frequency are also vital.
  • The design: Some microphones have simple designs, while others have LCD screens that can show you information about the configuration of the mic. There’s also how comfortable it is holding them – holding a poorly designed mic can hurt your hand after a while.
In this article, we will highlight the top 5 best DJ wireless microphones in 2024 based on these technical factors, other essential features, and their prices. Whether you are a professional DJ or just starting, this article will provide you with all the information you need to choose the best mic. Let’s get started!
1. Shure BLX288/PG58
Shure BLX288/PG58
The Shure BLX88 is a dual wireless receiver that paired with the PG58 line of microphones makes for a very sturdy and affordable option. The PG58 provides outstanding sound quality that’s just as crystal clear as the SM58 line, which says a lot since the latter is the preferred option in any professional setting. You can also pick PG58 mics that work within a specific range and communicate perfectly with the receiver – which, by the way, is compatible with other Shure mics. This combination is versatile, has gain control, a 100-foot range, a 50 Hz to 16 kHz frequency range, and is one of the most comfortable mics out there. Keep in mind that these mics use AA batteries, but by spending a few extra bucks you can get highly-compatible Shure rechargeable batteries. Guaranteed high-quality performance from Shure! This is the perfect mic because it’s not too expensive, it provides great quality for a DJ, the receiver is compact and easy to set up, and this particular offer comes with two PG58 cardioid mics, making it a clear value choice. You can get the microphones alone and a different receiver, though this receiver is one of the best-performing ones out there due to its accurate frequency auto-scan and pairing.
  • High-performance mics and receivers that are somewhat affordable
  • The best sound quality you can get from the PG58 mics (comparable to the SM58 mics)
  • The receiver has outstanding features that make it easy to use and is also compatible with other mics
  • It comes with two mics
  • It has a great range
  •  It’s still one of the priciest choices you can get – but still affordable considering its quality
If you need a reliable DJ wireless microphone, this offer is what you need. Numerous features, no compatibility issues, easy to set up, lightweight and compact, and it’s affordable even though they are high-performance devices. Still, it’s a high-end device and it can be considered expensive when compared to other options on this list. Also, keep in mind you’ll have to buy rechargeable batteries.
Quantitative Measurement
  • Build Quality: 9/10
  • Versatility: 9/10
  • Features: 9/10
  • Sound Quality: 10/10
  • Ease of Use: 9/10
2. ATW-1102 System 10 Wireless Handheld Microphone System
This one comes from Audio Technica, a brand that’s been steadily earning recognition in professional settings. The ATW-1102 System 10 is an affordable wireless microphone system that allows you to get the best-performing equipment within this range. The microphone is an ATW-T1002, which is a simple, yet powerful battery-powered handheld mic. It’s comfortable to use, it has a small screen that shows the channel it’s set up to, and a power-off button at the bottom. It’s ready to use out of the box because it comes paired with the ATW-R1100 receiver that works with the 2.4GHz (2400 to 2483.5 MHz) range to avoid interference. Like the one above, it has a standard 100-foot range, which is great for any type of venue. This particular system is an awesome pick if you’re looking for a balance between quality and price. However, keep in mind that it’s not comparable to the Shure mic above in either sound quality or build quality. Still, it will get the job done excellently if you only need one mic setup.
  • Good quality sound
  • Easy to use – it comes ready to use out of the box
  • It’s cheaper than the one above and still provides good quality
  • It’s perfect for pro and semi-professional use
  • It doesn’t usually have interference issues
  • It doesn’t sound as good as the one above
  • It’s not as durable either
If you’re looking for a cheaper alternative to anything made by Shure, Audio Technica is a good brand to fill that gap. This particular system will provide you with great features, easy-to-use and set-up receivers and mics, and good sound quality. Still, it’s not a professional mic per se, so we wouldn’t recommend it if you need immaculate quality and durability.
  • Build Quality: 8/10
  • Versatility: 7/10
  • Features: 8/10
  • Sound Quality: 7/10
  • Ease of Use: 9/10
3. AKG WMS45
AKG WMS45
AKG is a slightly less-known brand that provides great-quality mics- they are comparable to Sennheiser mics in terms of sound quality, which says a lot. The main reason why you must consider mics from this brand is that they are very affordable. The AKG WMS45 costs less than half of the price of the mic above while providing good sound and a similar design. The best part about this set is that you can buy several and use them in the same venue without running into interference issues. The system works with a frequency range between 500 and 865 MHz, making it very reliable. The downside of this choice is that the mics are somewhat flimsy and don’t have the best design. They do have a screen to show the band they’re using, but the switch is not comfortable to use and, since they’re made out of plastic, they don’t feel as comfortable to hold. They are also not as durable as any of the mics above. With that being said, it’s hard to find equally affordable systems that provide this level of sound quality.
  • Good sound quality
  • Excellent price
  • It’s a very reliable mic and receiver set
  • They’re not so durable
  • The mics are not comfortable to hold for long periods
  • The set is not the best for professional use
If you’re starting and are a bit overwhelmed by the price of high-quality sets of transmitters and receivers, this set is a sight for sore eyes. Not only do you get great sound quality, but also affordability and reliability with a single set. Sure, this is not a Shure mic that will last years of heavy use and a big brand name to back it up, but it will be worth every penny nonetheless.
  • Build Quality: 6/10
  • Versatility: 5/10
  • Features: 7/10
  • Sound Quality: 6/10
  • Ease of Use: 8/10
4. AKG DMS100
AKG DMS100
Another one from AKG! The AKG DMS100 professional digital wireless systems are a game-changer for performers and presenters looking for high-quality sound and ease of use. The system combines good sound quality with four channels of license-free 2.4GHz operation, good battery life, and ease of use. This set is available in two options, one with an AKG handheld microphone and one with a bodypack for instrument use. The bodypack is instrument-ready and can also be combined with a wide range of AKG headsets or clip-on mics (available separately) for singers or presenters.
They work with 24-bit/48 kHz uncompressed audio coding to get crisp quality sound with zero interference. It operates in the 2.4GHz band, a global license-free space. This means that you don’t have to worry about interference or finding available wireless channels. Up to four DMS100 systems can be synced and used simultaneously.
This one is in fourth place because it provides similar quality to the one above while being slightly more advanced, and pricier. We don’t consider this one to be much better than the one above. However, there are more instances of professional uses and advocates for the DMS100 than for the one above. Overall, the AKG DMS100 digital wireless system is a dependable solution for performers, presenters, fitness instructors, educators, and anyone who seeks both studio-quality sound and freedom of movement onstage.
  • Slightly better quality than the one above
  • High-quality sound for this price range
  • It has a better and cleaner design than the one above
  • It’s much more common in semi-professional and professional settings
  • It’s slightly pricier
If you have some extra budget and consider the slightly improved quality justifies its price, then this one is a good choice that’s superior to the AKG WMS45.
  • Versatility: 5/10
  • Features: 7/10
  • Sound Quality: 8/10
  • Ease of Use: 8/10
5. Bietrun WXM19 Rechargeable Wireless Microphone
Bietrun is an unknown brand that offers one of the most affordable rechargeable wireless mics. The WXM19 is a good choice if you’re a new DJ that is yet to build a reputation and a steady calendar of gigs. It’s a value product that offers decent quality and a much better price. The microphone is easy to use, with plug-and-play functionality that only requires a mic input on your equipment. The display shows battery power and signal strength in real time. The microphone is also built with an alloy material that is harder, lighter, and more wear-resistant than other entry-level mics. It needs two AA batteries (not included) and the rechargeable receiver has a 650mAh battery that provides up to 4 hours of work time and fully charges in 3 hours. Overall, this is a decent mic that will do a decent job – don’t expect anything outstanding out of it, except for its price.
  • It’s got the lowest price on this list
  • It’s easy to use – it’s plug-and-play!
  • It has decent features like a display, works with Bluetooth, and has a nice range
  • It’s a fairly durable mic for its price
  • It’s the worst-sounding mic on this list
  • It’s got a limited range when compared to the other mics
  • The receiver lasts only 4 hours
The best thing you get from buying this option is that you get to save a lot of money, while still getting the job done. Of course, it’s nowhere near professional or semi-professional quality!
  • Build Quality: 7/10
  • Versatility: 6/10
  • Features: 6/10
  • Ease of Use: 8/10
Comparison
Microphone ModelBuild QualityVersatilityFeaturesSound QualityEase of UseTotal Points
Shure BLX288/PG5899910946/9.2
ATW-1102 System 108787939/7.8
AKG WMS456576832/6.4
AKG DMS1008578836/7.2
Bietrun WXM197666833/6.6
Table Breakdown
From all the perspectives, the Shure BLX288/PG58 system comes out on top with an average score of 9.2. It’s much superior to the rest of the systems on this list. It’s followed by the ATW- 1102 System 10 with 7.8 points, which stands out as an excellent option with the second-best sound quality. The AKG DMS100, Bietrun WXM19, and AKG WMS45 systems received average scores of 7.2, 6.6, and 6.4 points, respectively. The DMS is superior among the low-budget picks in terms of sound and design quality. The Bietrun WXM19 and the AKG WMS45 are good overall options you must consider depending on your specific needs – we prefer the AKG system because it uses a standard receiver.
Shure BLX288/PG58 is the top-ranked mic in this list. However, the Shure microphone system is also at the top of our reviews. We’re not particularly biased toward using this brand. It’s only that when compared to its competitors, it’s easy to distinguish the high sound quality and durability it provides with all its devices. That’s why it’s predominantly used in professional settings – DJs will get the absolute best sound with them for years. However, if the price is a problem, we’ve provided you with four extra options of varying prices that can help you out depending on what stage of your journey as a DJ. Does any of them work for you? Let us know!
1. Are Wireless DJ Microphones Better Than Cabled Solutions?
Nowadays, wireless technologies have improved a lot, narrowing the difference between cabled and wireless mics. Usually, there’s no significant difference in quality, although high-end wireless microphones and equipment provide the best results.
2. Are Wireless DJ Microphones More Expensive?
Overall, yes. However, when comparing high-end wireless and cabled microphone solutions, the price range doesn’t vary as much because the quality is just about the same. With that said some low-end cabled solutions can be much cheaper than their wireless counterparts.
3. Can You Use Several Wireless Mics With the Same Receiver?
It depends. Some receivers, like the first pick of this list, are dual, so you can pair two mics at the same time. However, not all receivers have this function, and most of them use a single-channel configuration.
Facebook
Twitter
Pinterest
Related Posts
