6 Best Budget USB Microphones for Vocals in 2024
Are you looking to take your vocal recordings to the next level without breaking the bank? The right USB microphone can be the key to producing crisp, clear audio for podcasts, music, or streaming from the comfort of your home. With an overwhelming sea of options, it’s challenging to find the perfect blend of quality and affordability. Fear not! We’ve compiled a list of the best budget USB microphones that ensure you don’t have to compromise on sound quality, even on a tight budget. Dive in as we unveil our top picks that promise to hit the right notes with your vocals.
When searching for the best budget USB microphone for recording vocals, consider these essential criteria to ensure you get great quality without breaking the bank:
1. Sound Quality: The most crucial factor is the clarity and richness of the recording. Look for a microphone with a wide frequency response and high resolution.
2. Pick-up Pattern: Cardioid microphones are generally preferred for vocals as they capture sound from the front, reducing background noise.
3. Build Quality: A durable microphone will last longer and often performs better in terms of reducing handling noise.
4. Ease of Use: Plug-and-play capability with simple controls is ideal for users without technical expertise.
5. Compatibility: Ensure the microphone works seamlessly with your recording device and software.
6. Additional Features: Look for helpful extras like built-in headphone jacks for real-time monitoring, or controls to adjust gain and mute the microphone.
With these criteria in mind, here’s a list of top budget USB microphones that provide excellent recording quality for vocals:
MicrophoneApprox. Price (USD)Polar PatternFrequency ResponseConnectivityOther Key Features
Hollyland Lark M2$139Omnidirectional20Hz – 20kHzUSB, Lightning, and 3.5mm jackEnvironmental Noise Cancellation, Plug ‘n Play, Auto Pairing, Mono and Stereo recording modes
Audio-Technica AT2020USB+$130 – $150Cardioid20Hz – 20kHzUSBBuilt-in headphone jack, mix control, volume control
Blue Snowball Ice$40 – $60Cardioid40Hz – 18kHzUSBPlug ‘n Play, Adjustable stand, No latency monitoring
Samson Meteor Mic USB Studio Mic$60 – $80Cardioid20Hz – 20kHzUSBFold-back leg design, Mute button, Headphone output
Fifine Metal Condenser Recording Mic$30 – $50Cardioid20Hz – 20kHzUSBAdjustable tripod stand, Volume control, No-latency monitoring
Rode NT-USB Mini$100 – $120Cardioid20Hz – 20kHzUSBDetachable magnetic stand, Built-in pop filter, DSP-free
Note: Actual specifications may vary, and extra features like the availability of real-time monitoring (listening to the sound as it’s being recorded without latency) can be very important for vocal recording, so consider this when choosing a mic. Be sure to check up-to-date product specifications and availability from the seller or manufacturer when making your decision.
Hollyland Lark M2
dsLxd5RCPPyR6GyOlBU p1JG4ssnvp1HWgZHgToEGurQ5GnQE qUc7 jiOn9 s3rLMUgE30Ol5YQ8CA0AMin hFex50WbOtLQj
If you’re seeking a USB mic because you don’t want to compromise on the sound quality of your video content, the Hollyland Lark M2 can be your ideal budget-friendly choice. It is a wireless microphone system with a transmitter (TX), receiver (RX), charging case, and numerous accessories. Weighing only 9 grams, the TX has a compact design that you can wear without the fear of sagging or drooping throughout your session.
lark m2 box
Hollyland Lark M2
Learn More
But that’s not everything special about this mic. The Lark M2 gives you multiple wearing options to fit your requirements. You can wear it like a necklace, attach the TX through the magnet, or clip it on your shirt. So whatever you prefer, Lark M2 ensures you never go out of style. This wireless microphone has the latest features, like the Laser Direct Structuring antenna, for uninterrupted wireless coverage of up to 1000ft.
Now, if you’re wondering whether the mic connects to your PC or laptop’s USB port, stay relaxed! Lark M2 has variations when it comes to connectivity. While it has USB-C and lightning connectors, it also provides a 3.5mm TRS to TRS cable to attach to your mirrorless and DSLR cameras. If you have a USB-A port on your PC, Lark M2 also gives you the USB-A to USB-C cable to connect the RX.
  • Type: Wireless lavalier
  • Polar Pattern: Omnidirectional
  • Sensitivity: -37 dBV +/- 2dB @ 1kHz
  • SNR: > 70dB
  • Sample Rate: 48kHz
  • Bit Depth: 24-bit
  • Connector: USB, 3.5mm jack, and lightning
  • Sound Pressure Level: 115dB
  • Battery Life of TX: Up to 10 hours
  • Batter Life of RX: Up to 9 hours
  • Charging Time TX/RX: Up to 2 hours
  • The microphone has a cable-free and simple setup
  • The audio quality is decent and better than bulky USB mics
  • It is an all-in-one solution for audio recording due to its compatibility with numerous devices
  • Users reported the high sensitivity of transmitters
The USB Type-C variant is around $139 on Amazon US. However, the price may vary if you choose another version or the company decides to change it.
The Hollyland Lark M2 is one of the best USB wireless microphones that complement all audio and video recording devices. At an affordable price range, it is difficult to find the features and high specifications that this microphone system offers.
lark m2 box
Hollyland Lark M2
Learn More
image 1262
Overview
The Audio-Technica AT2020USB+ is a standout in the realm of budget USB microphones, particularly for vocalists who require studio-quality sound without the studio price tag. From its sleek, elegant design to its exceptional audio clarity, this microphone is a powerhouse hidden within an unassuming package. Having personally tested a variety of USB mics in search of one that balances cost with performance, I found the AT2020USB+ to be a refreshing discovery that doesn’t cut corners where it truly counts. It captures the nuances of vocal performances effortlessly, making it an ideal mic for singers, podcasters, and voice-over artists who demand professional standards.
  • Microphone Type: Condenser
  • Polar Pattern: Cardioid
  • Sample Rate: 44.1/48 kHz
  • Bit Depth: 16 bit
  • Connectivity: USB
  • Headphone Jack: Yes, with volume control
  • Controls: Mix control, Volume control
  • Compatibility: Mac and Windows
  • The sound quality is exceptionally crisp and clear, capturing a full range of tones from lower pitches to higher ones without distortion or noise.
  • The cardioid polar pattern is excellent for vocal isolation, minimizing background noises and focusing on the speaker’s voice.
  • It comes with a built-in headphone jack and controls, which is incredibly handy for real-time monitoring without any perceptible latency.
  • The mix control allows you to blend microphone input and pre-recorded audio seamlessly—a feature often appreciated in more complex recording setups.
  • With its 16-bit audio, while ample for most applications, audio purists or professionals may look for microphones offering 24-bit depth for even greater dynamic range.
  • The microphone stand included is serviceable but might not provide the stability or adjustability that some users may need; a separate boom or mic stand might be a preferable choice.
  • It is on the higher end of the “budget” spectrum, which might push the limits of what some are willing to spend.
As for the price, it ranges quite a bit depending on where you shop and current promotions, but generally, it’s found at around $100 to $150. Although not the cheapest option on the list, the Audio-Technica AT2020USB+ delivers a level of quality that makes it well worth the investment, especially if you’re serious about the quality of your vocal recordings.
In conclusion, the Audio-Technica AT2020USB+ goes beyond expectations for a budget USB microphone. It’s a strong contender for anyone eager to produce professional-sounding recordings without splurging on more elaborate audio setups. The few downsides are eclipsed by its outstanding performance, particularly in the rendition of vocals, which makes this microphone my top recommendation for those in need of high-fidelity audio on a budget.
Blue Snowball Ice
image 1263
Overview
The Blue Snowball Ice is a distinctive looking microphone, round like its namesake, that features a simple plug-and-play design ideal for those new to recording or streaming. It’s an entry-level mic with a robust build, and although it may lack some of the advanced features of more expensive microphones, it’s a solid performer at an affordable price. The sound quality is surprisingly clear for its cost, making it an attractive option for podcasters, gamers, and aspiring musicians who want to record vocals without breaking the bank.
In my use, I’ve found the Snowball Ice to be surprisingly versatile. Its cardioid pickup pattern does a good job at focusing on sound directly in front of it, which means your vocals are captured clearly, with minimal background noise. It’s also pretty forgiving with its placement, so you don’t need to be an audio engineer to get a decent sound out of it.
  • Transducer Type: Condenser, Pressure Gradient With USB digital output
  • Polar Patterns: Cardioid
  • Frequency Response: 40 –18 kHz
  • Sample/Word Rate: 44.1 kHz/16 bit
  • Weight: 460g
  • Dimensions: 325mm (circumference)
  • Plug-and-play USB connectivity for easy setup
  • Clear audio quality for the price
  • Sturdy, attractive design
  • Versatile use cases
  • Compatible with both Mac and PC
  • No onboard gain control or mute button
  • Limited to a cardioid polar pattern
  • The stand could be more stable/adjustable
At the time of this writing, the Blue Snowball Ice typically retails around $50, making it an excellent value for the money. However, prices may vary based on retailer discounts and promotions. It strikes a pleasing balance between quality and affordability, an aspect that’s paramount for anyone looking to get good vocal recordings on a budget.
In conclusion, the Blue Snowball Ice is a smart choice for users seeking a straightforward solution for quality vocal recordings. Its sound performance, ease of use, and entry-level pricing collectively earn it a spot on our best budget USB microphones list. Sure, it’s not without its limitations, but for the cost-conscious consumer, it represents a harmonious compromise between functionality and expense.
Samson Meteor Mic USB Studio Microphone
image 1264
Overview
The Samson Meteor Mic strikes a fantastic balance between quality, portability, and price, which is no small feat in the saturated market of USB microphones designed for vocal recordings. What first catches your eye is its retro-futuristic design – a polished, chrome-finished body with fold-back legs that not only add stability but also contribute to its almost otherworldly charm.
When you dive deeper into its performance, the Meteor Mic doesn’t disappoint. Unlike many budget options that tend to cut corners on sound quality, this microphone offers clear and natural sound capture that’s quite impressive for its price point. It does an excellent job for podcasting, streaming, or even some basic home recording setups. The cardioid pickup pattern helps to isolate your vocals, minimizing background noises that may be lurking in your recording environment.
However, the Meteor Mic is not without its quirks. It’s sensitive, which is a double-edged sword: while it can catch the nuanced tones of your voice, it can also pick up unwanted sounds if you’re not in a reasonably quiet space. Its all-metal construction gives it durability, but the flip side is that it’s heavier than some of its plastic counterparts, which might be a consideration if portability is a top priority for you.
  • Sample Rate: 44.1/48kHz
  • Bit Rate: 16 bit
  • Headphone Jack: Yes, with zero-latency monitoring
  • Controls: Volume knob, mute button
  • Eye-catching design that combines vintage looks with modern functionality.
  • Highly portable with foldable legs and compact size.
  • Solid build that feels more expensive than it is.
  • Competent sound quality, particularly for vocals.
  • No frills easy setup that’s perfect for beginners.
  • Heavier due to metal construction, which could impact portability.
  • Sensitive mic that may require a treated space for the best results.
  • Limited in terms of customization and sound shaping when compared to more sophisticated models.
The Samson Meteor Mic USB Studio Microphone typically retails for around $70, depending on the retailer and any ongoing promotions. This places it in an affordable bracket for those seeking a reliable, no-nonsense USB microphone for vocal work that doesn’t skimp on build or sound quality. In my opinion, the Samson Meteor Mic offers a lot of value for its price and is a solid choice for those who want a straightforward plug-and-play solution without the fuss of additional audio equipment.
Overall, the Meteor Mic is a standout choice for budget-conscious consumers. It’s perfect for those who are just starting out with recording or looking for an inexpensive yet reliable option for improving their audio quality during calls or while streaming. Its unique design and robust build quality offer an attractive package that’s tough to beat without spending significantly more.
Fifine Metal Condenser Recording Microphone
image 1265
Overview:
The Fifine Metal Condenser Recording Microphone (likely the K669B model if we’re talking about a popular budget option) is a fantastic little piece of equipment that punches well above its weight class. My experience with this microphone has honestly been pretty surprising. Not only does it have a solid, hefty build which gives it a premium feel, but it also delivers clear and crisp sound, which is quite unexpected at its price point. The microphone’s design is sleek and no-nonsense, including a durable tripod stand that allows for easy adjustment, and it’s extremely user-friendly; plug it into your USB port, and you’re pretty much ready to go.
Its performance in capturing vocals is rather impressive. Now, keep in mind it’s not going to give you the same quality as a high-end studio mic, but for beginner podcasters, streamers, or anyone dipping their toes into music recording, it offers fantastic value. The cardioid pickup pattern does a decent job at isolating your voice from background noise – just be mindful, as it can still pick up keystrokes or mouse clicks if you’re typing during use.
  • Type: Condenser
  • Frequency Response: 20Hz-20kHz
  • Sensitivity: -34dB±30%
  • S/N Ratio: 78dB
  • Connector: USB
  • Cable length: Approximately 6 feet
Pros & Cons:
  • Great build quality with a metal body; this microphone feels sturdy.
  • Plug-and-play with no need for additional drivers or software, which is super convenient.
  • The sound quality is impressive for a budget microphone; it’s capable of capturing detailed vocals.
  • Includes a tripod stand and the necessary cable, so you have everything you need right out of the box.
  • Being a condenser mic, it can pick up ambient noise more readily than dynamic mics—something to consider if you’re in a noisy environment.
  • It lacks onboard gain control, meaning you have to adjust the input volume from your computer.
  • The tripod stand, while useful, is not the most stable and might not position the mic at an ideal height for everyone.
The Fifine Metal Condenser Recording Microphone often retails around $35 to $40. Given its robust construction and audio quality, it’s a steal. It outperforms many other microphones in this price bracket and provides a solid starting point for anyone who needs a reliable microphone without breaking the bank.
In my opinion, for anyone on a tight budget looking to improve their audio setup, whether for hobbyist recording, streaming, or simple vocal work, the Fifine Metal Condenser Recording Microphone is a strong contender. It’s a practical choice that delivers quality where it counts, and its shortcomings are well within reason given its budget-friendly nature. This mic is definitely a smart buy for anyone starting out or operating within tight financial constraints.
Rode NT-USB Mini
image 1266
Overview:
Compact, sleek, and user-friendly, the Rode NT-USB Mini is a fantastic budget-friendly USB microphone that punches above its weight in terms of vocal quality. Designed with home studios and mobile recording setups in mind, it doesn’t take a genius to set it up: just plug it in, and you’re good to go. The microphone provides smooth, studio-quality sound that flatters various vocal types, from spoken word to singing, making it a go-to choice for podcasters, streamers, and musicians looking for an affordable option.
In my experience, the NT-USB Mini stands out for its exceptional clarity. When compared to other microphones in the same price range, it roots out a lot of the competition with its richer tones and less noise interference. Although lacking some of the bells and whistles of higher-end models, it focuses on delivering the essentials very well, which is pristine vocal capture.
  • Acoustic Principle: Condenser
  • Maximum SPL: 110dB
  • Bit Depth: 24-bit
  • Connection Type: USB-C
  • Output: 3.5mm headphone jack for zero-latency monitoring
  • Outstanding audio quality for the price with a clear, warm sound ideal for vocals.
  • It’s incredibly easy to set up, thanks to its USB connectivity.
  • Compact and sturdy design that’s great for small spaces and portability.
  • Integrated pop filter softens plosive sounds and maintains clear speech.
  • The magnetic desk stand minimizes vibrations and is detachable.
  • Lacks onboard gain control, which means you’ll have to adjust input levels through your computer.
  • The cardioid polar pattern is excellent for vocals but might not be versatile enough for all recording situations.
Priced at around $99, the NT-USB Mini is an excellent value for those in need of a quality vocal mic without breaking the bank. Its price point makes it highly accessible for beginners and those looking to upgrade from basic models, while its performance is impressive enough to satisfy the more discerning budget-conscious user.
The Rode NT-USB Mini is a stand-out contender in the sea of budget USB microphones for vocalists. The simplicity of “plug-and-play,” matched with the quality it offers, is a testament to Rode’s commitment to making professional-grade recording accessible to everyone. If you’re in search of a microphone that will give your vocal recordings that polished sheen without leaving your wallet empty, this is the one to beat in its category.
In the search for the best budget USB microphone for vocals, the options listed offer an impressive balance of quality, versatility, and affordability. Whether you’re podcasting, streaming, or laying down vocal tracks, these microphones stand out for their remarkable performance without breaking the bank. Remember, the best mic for you will depend on your specific needs and the specific characteristics of your voice and recording space. Happy recording!
FAQs:
  1. Do I need additional equipment to use a USB microphone for recording vocals?
    Most USB microphones are plug-and-play, requiring no extra gear. However, for best results, you might consider a pop filter and a stable mic stand or boom arm.
  2. Can a budget USB microphone compete with professional studio mics?
    While budget microphones can’t match the quality of high-end studio mics, they can still produce excellent sound suitable for amateur recording, podcasting, and streaming.
  3. How do I improve the vocal recordings on my budget USB microphone?
    Ensure you record in a quiet, non-reverberant space. Position the microphone properly, use pop filters, and experiment with recording software to enhance your audio quality.
Facebook
Twitter
Pinterest
Picture of John Doe
John Doe
Related Posts
