New Product Coming
DAYS
HRS
MINS
SECS
5 Best Computer Microphones for Conference Calls in 2024
Are you looking to enhance your audio experience during conference calls? With the endless array of computer microphones on the market, choosing the ideal one can be daunting. Whether you’re a remote worker, a podcast enthusiast, or simply aiming for crystal-clear communication, the right mic can make all the difference. To save you the hassle, we’ve reviewed and compiled a list of the best computer microphones that promise to deliver superior sound quality, noise reduction, and user-friendly features. Dive into our top picks to find your perfect match for seamless and professional-sounding conference calls.
When searching for the best computer microphone for conference calls, consider the following criteria to ensure clear and effective communication:
  1. Sound Quality: A good microphone captures your voice clearly without distortion or background noise. Look for mics with noise-cancellation features.
  2. Pickup Pattern: Depending on your environment, you might need a mic with a cardioid pattern (picks up sound in front of the mic) for solo use or an omnidirectional pattern (picks up sound from all directions) for group settings.
  3. Connectivity: USB microphones are plug-and-play, making them user-friendly. Some may prefer wireless options for mobility, whereas others might need a traditional 3.5mm jack.
  4. Compatibility: Check that the microphone is compatible with your operating system and your preferred conferencing software.
  5. Ease of Use: Look for mics with simple setup processes and user-friendly controls for volume and muting.
  6. Durability and Portability: If you plan to take the microphone to different locations, it should be sturdy and easily transportable.
  7. Price: The mic should offer good value for the price, fitting within your budget while meeting your specific conferencing needs.
  8. Additional Features: Extra features like an included stand or pop filter can be valuable additions.
We will now review microphones that are recognized for excelling in these aspects, ensuring that you make an informed decision for your conference call needs.
Feature/SpecBlue Yeti USB MicrophoneJabra Speak 710 UCRode NT-USB MiniShure MV5Poly Sync 20 USB
Approximate Price (USD)$130$300$100$110$130
Connection TypeUSBBluetooth and USBUSBLightning or USBBluetooth and USB
Polar PatternsCardioid, Bidirectional, OmnidirectionalOmnidirectionalCardioidCardioidOmnidirectional
Frequency Response20Hz – 20kHz150Hz – 20kHz20Hz – 20kHz20Hz – 20kHz100Hz – 20kHz
Recording Quality16-bit/48kHzNA24-bit/48kHz24-bit/48kHzNA
PortabilityStationary, not ideal for moving aroundHighly Portable, Built for travelRelatively portable but stationary use recommendedPortable, Comes with standHighly portable, Built for travel
Speaker FunctionNoYes, High-quality speakerNoNoYes, Speaker function included
Built-in BatteryNoYes, Up to 15 hours on a single chargeNoNoYes, Up to 20 hours on a single charge
Suitable EnvironmentQuiet indoor settingsAny setting, adaptable due to portable designQuiet indoor settingsQuiet indoor settingsVarious settings, adaptable
Additional FeaturesMute button, Gain control, Headphone jackTouch-sensitive controls, Omni-directional microphoneDetachable magnetic stand, Headphone jackDSP preset modes (vocals, flat, instrument), AppWater-resistant, Smartphone charger
Please remember that prices and specs can change, and for the best decision, you should check current listings and possibly test the devices to see which one meets your particular needs for conference calls.
image 1353
Overview:
The Blue Yeti is a top-of-the-line USB microphone that has gained massive popularity for its exceptional sound quality and versatility. It’s a plug-and-play mic, meaning it doesn’t require any special drivers or software – you just plug it into your computer’s USB port and you’re ready to go. The design is modern and professional, with a sturdy build that feels like it’s made to last.
In my experience, the Blue Yeti delivers crystal clear audio, capturing the full range of the human voice with impressive clarity. It’s perfect for conference calls because it offers a variety of pickup patterns; you can set it to cardioid mode for solo use or omnidirectional mode to pick up sound equally from all directions, which is great for group settings. Another standout feature is the headphone jack for real-time monitoring – this is incredibly helpful for ensuring audio quality during calls.
  • Pickup Patterns: Cardioid, Bidirectional, Omnidirectional, Stereo
  • Sample Rate: 48kHz
  • Bit Rate: 16-bit
  • Connection Type: USB
  • Multiple pickup patterns make it perfect for various scenarios.
  • The real-time monitoring feature helps avoid audio mishaps.
  • The sound quality is superb, which means you sound professional.
  • No need for additional software; it’s very user-friendly.
  • Aesthetic design that fits well in a professional setup.
  • The size of the microphone may take up a fair bit of desk space.
  • It can pick up background noise if not set up correctly.
  • The price might be a bit steep for those on a tight budget.
The Blue Yeti USB Microphone usually sits in the mid-range price bracket for microphones. While it may not be the cheapest option on the market, the investment is justified by its features and performance. It’s usually priced anywhere from $100 to $130, depending on the retailer and any ongoing sales.
In conclusion, if you’re looking for a microphone that will elevate your conference call experience with minimal fuss, the Blue Yeti should be right at the top of your list. It’s an all-around performer that excels in both solo and group settings, making it a versatile addition to any professional setup.
Jabra Speak 710 UC Wireless Bluetooth Speaker & Speakerphone
image 1354
Overview:
The Jabra Speak 710 UC is a premium portable conference speakerphone designed to provide outstanding sound quality and seamless connectivity for conference calls. Unlike traditional microphones, the Speak 710 UC stands out with its dual functionality, serving both as a speaker and microphone. Elegant and sophisticated in design, the device is intuitively crafted with plug-and-play simplicity in mind, making it ideal for professionals who demand flexibility and quality in their communication tools.
In my experience, the audio clarity is splendid – voices come through naturally without the tinny echo you might encounter with lesser devices. Its ability to pick up sound in a 360-degree radius ensures that participants around the table are heard without huddling close to the device. Furthermore, its portability and wireless connectivity via Bluetooth or USB are unquestionable boons for dynamic work environments and on-the-go meetings.
  • Connectivity: Bluetooth and USB
  • Microphone type: Omni-directional
  • Wireless range: Up to 30 meters (100 feet)
  • Compatible with all leading UC platforms
  • Battery life: Up to 15 hours of talk time
  • Simultaneous connection: Can pair with up to 8 devices, connected to two at the same time (PC and smartphone)
  • Exceptional sound quality for both mic and speaker
  • Highly portable with premium build quality
  • Easy to set up and use with multiple devices
  • Long-lasting battery life adds to its mobile convenience
  • Capable of being linked to another Jabra 710 for stereo sound
  • Price may be higher compared to some other conference microphones
  • May not suit those looking solely for a microphone without speaker capabilities
  • The touch-sensitive buttons can be overly responsive to unintended touches
The price of the Jabra Speak 710 UC can be a bit on the higher side, reflecting its position as a high-end product in the market. However, considering the value it adds in terms of audio quality and usability for professional settings, the investment is well-justified for those requiring reliable and versatile conferencing tools.
In summary, the Jabra Speak 710 UC is an excellent choice for businesses and professionals seeking a sophisticated audio solution for conference calls. Its superb sound, user-friendly design, and adaptability to different use cases make it a standout product in its category. While it may demand a premium outlay, for those who prioritize audio excellence and convenience, it is money well spent.
Rode NT-USB Mini USB Condenser Microphone
image 1355
Overview:
The Rode NT-USB Mini is a compact, studio-quality USB microphone designed for podcasters, musicians, and conference call participants seeking exceptional audio clarity. My experience with this microphone has been overwhelmingly positive; it strikes an excellent balance between professional sound quality and user-friendly features. It’s robust, well-built, and manages to capture voice with exceptional detail, making it a formidable contender for anyone looking to upgrade their conference call audio set-up.
The microphone’s cardioid pickup pattern excels at minimizing background noise, focusing on your voice instead. This is particularly useful in common conference call scenarios, where distracting sounds can compromise communication. With its smooth frequency response and built-in pop filter, plosive sounds are well controlled, ensuring your speech remains clear and intelligible.
  • Acoustic Principle: Pressure gradient
  • Active Electronics: Electret condenser, A/D and USB interface
  • Polar Pattern: Cardioid
  • Frequency Range: 20 Hz – 20 kHz
  • Output: USB-C
  • Maximum SPL: 121dB SPL
  • Sample Rates: 48 kHz
  • Bus Powered
  • Dimensions: 141.9 x 54.5 x 89.3 mm
  • Weight: 585g
  • Exceptional sound quality that’s clear and crisp
  • User-friendly setup; no drivers needed, just plug and play
  • Sturdy, attractive design that feels durable
  • Integrated pop shield minimizes plosives
  • The included magnetic desk stand is both functional and stylish
  • Lack of onboard gain control might be limiting for some users
  • The cardioid pattern is great for voice focus but not designed for multi-person recordings
  • Fixed USB-C cable can limit placement options
The Rode NT-USB Mini USB Condenser Microphone typically retails around the $99 mark, making it an accessible option for those investing in a reliable, high-quality microphone without stretching into professional studio gear territory. It represents excellent value for money considering the audio fidelity it delivers.
In my opinion, the Rode NT-USB Mini holds its own against pricier microphones. It excels in its primary function – capturing clear, undistorted audio. The simplicity of its design and its straightforward functionality make it a perfect candidate for anyone who wants professional-sounding conference calls without the hassle of a complex setup.
Shure MV5 Digital Condenser Microphone
image 1356
Overview:
The Shure MV5 is a compact yet robust digital microphone that promises to deliver studio-quality audio during your conference calls. What immediately caught my attention was how the microphone aligns a user-friendly experience with Shure’s reputable performance standards.
Designed with simplicity in mind, the MV5 boasts a plug-and-play approach that’s fantastic for someone who isn’t technically-inclined. You can connect it to your computer or even your mobile devices through its USB and Lightning cables. The MV5 stands out for its versatility and its DSP (Digital Signal Processing) modes, which allow you to tailor the audio pickup to your needs – whether you’re on a call or recording music.
  • Type: Digital condenser
  • Connectivity: USB, Lightning
  • Frequency Response: 20 Hz to 20,000 Hz
  • DSP Modes: Voice, Instrument, Flat
  • Form Factor: Portable
  • Accessory: Detachable desktop stand
  • The audio fidelity is excellent, and the voice presets enhance vocal clarity in a way that makes conversations crisp and professional.
  • The build, though not entirely metal, feels durable and well-suited for transport without concern for easy damage.
  • Its compact size is perfect for a small desk or when you need to pack it for travel.
  • The additional option to connect directly to iOS devices adds to its appeal, especially if you find yourself working remotely.
  • I do miss having more physical controls on the microphone itself; the single touch panel can feel limiting if you’re trying to adjust on the fly.
  • It lacks some advanced features like gain control or a mute button, which can be found in other models within the same price range.
The Shure MV5 typically sits around the mid-range price point for USB microphones. While it isn’t the cheapest option available, the price can be justified given the audio quality and the brand reliability. However, it’s worth noting that there are more budget-friendly alternatives for those who are cost-conscious.
Personal Opinion:
Overall, the Shure MV5 impresses with its audio quality and simple design. It may not be crammed with features, but it delivers where it matters most. This microphone would be a solid addition for anyone who frequently joins conference calls and is looking for dependable and clear audio without the complexity of professional recording gear. It’s not overkill, but it certainly over-delivers on performance within the realm of what it’s designed to do.
Poly (Plantronics + Polycom) Sync 20 USB Bluetooth Speakerphone
image 1357
Overview:
The Poly Sync 20 is a versatile and portable speakerphone designed for professionals who require pristine audio quality during conference calls. Upon using this device, I was thoroughly impressed by its capacity to capture voices with superb clarity and consistent volume level, a feature that immediately sets it apart from many others in the crowded market of conference call equipment.
The design is sleek and modern, and its compact form factor means it takes up minimal space on a desk, and is equally easy to throw into a laptop bag. During my testing, I found that the touch controls are intuitive and responsive, allowing smooth operation during calls with minimal distractions.
The Sync 20 is also designed with versatility in mind – not only does it serve as a high-end microphone for calls, but it also functions as a portable speaker. In my experience, the audio performance was above par for a device of this size, offering a rich sound profile when used for listening to music or other media.
  • Microphone Type: Multi-microphone array
  • Connectivity: USB-A, USB-C, Bluetooth
  • Battery Life: Up to 20 hours talk time
  • Features: Full duplex audio, echo and noise cancellation, IP64 dust and water resistance
  • Compatibility: Works with most popular online voice call services
  • The sound quality for both the microphones and the speaker exceeded my expectations. Conversations are crisp and clear without any noticeable echo, which can be a game-changer during long conference calls.
  • The battery life is remarkable. It often outlasts a full workday, and because it can be used as a power bank to charge other devices, it doubles as an essential tech tool.
  • It’s highly portable and durable, which makes it an excellent option for remote workers or those with on-the-go professions.
  • Price might be a sticking point for some users, especially for those who don’t require the broad feature set that the Sync 20 offers.
  • While Bluetooth connectivity is a plus, I noticed occasional lag or connection drops, which although infrequent, could be disruptive in important calls.
The Poly Sync 20 sits at a premium price point, typically retailing around $200. This might initially seem steep for a personal speakerphone, but after extensive use, I believe the price is justified by its performance, build quality, and the seamless integration it offers into a professional workflow.
In summary, if you’re looking for a high-quality microphone that doubles as a speaker and is built for the mobile professional, the Poly Sync 20 should definitely be at the top of your shortlist. While it may be pricier than some alternatives, the investment seems worthwhile for those who regularly engage in conference calls and demand superior audio fidelity and reliability.
In the digital age where virtual meetings have become a staple, choosing the right microphone is pivotal for clear communication. We’ve explored several top contenders, each offering unique features to enhance your conference calls. From noise-canceling capabilities to crystal-clear audio pickups, the perfect microphone can elevate your online presence, making meetings more productive and professional. Remember to consider compatibility, design, and user-friendliness when making your selection. Investing in a quality microphone is investing in effective collaboration.
FAQs:
  1. What factors should I consider when choosing a microphone for conference calls?
  • Look for microphones with noise-canceling features, good sound quality, ease of use, compatibility with your devices, and an appropriate pickup pattern for your environment.
  1. Can I use a gaming microphone for professional conference calls?
  • Yes, gaming microphones are often designed with high-quality audio in mind, and many are suitable for professional conference calls, but ensure they don’t have overly aggressive styling if you’re concerned about maintaining a professional appearance.
  1. Do I need a separate microphone if my laptop has a built-in one?
  • While built-in microphones are convenient, an external microphone usually offers superior audio clarity, noise reduction, and can help to minimize feedback during conference calls.
Facebook
Twitter
Pinterest
Related Posts
