When it comes to maximizing efficiency and clarity in a call center, having the right microphone can make all the difference. With operators depending on crystal-clear audio to communicate effectively, the choice of microphone is critical. It can impact everything from customer satisfaction to operator comfort throughout long shifts. Not all microphones are created equal, and there are many on the market tailored to the distinctive needs of call center professionals. In this listicle, we’ll be reviewing some of the best microphones that blend superior sound quality, noise cancellation, and long-wearing comfort, ensuring your call center operates smoothly and your team communicates with unparalleled clarity.
When selecting the best microphone for call center use, it’s important to consider several key criteria to ensure clear communication with customers. Here’s a brief overview of the factors you should take into account:
- Audio Quality: The most critical factor is how clear the microphone can capture your voice. Look for a microphone that provides crisp, clear audio without any static or distortion.
- Noise Cancellation: Call centers are typically noisy environments. A microphone with effective noise-cancellation technology can help minimize background sounds and ensure your voice is heard without interference.
- Comfort & Fit: Since call center agents wear their headsets for long periods, the microphone should be part of a comfortable headset that can be worn without causing discomfort.
- Durability: These microphones are used extensively, often around the clock, so they must be durable and able to withstand constant use.
- Compatibility: The microphone needs to work seamlessly with your call center’s hardware and software systems without the need for complicated setups.
- Features: Additional features like a mute button, volume control, or a boom arm that can be adjusted or swiveled out of the way can enhance usability.
- Price: While not compromising on quality, the microphone should also fit within the budget of the call center’s operational costs.
Choosing the best microphone within these criteria will ensure that communication remains clear, efficient, and professional, which is vital for maintaining customer satisfaction.
Features / Product | Plantronics EncorePro HW720 | Jabra Biz 2400 II USB Duo CC | Logitech H390 USB Headset | Sennheiser SC 60 USB CTRL Headset | BlueParrott C300-XT Noise Canceling Headset |
Price (Estimated)* | $100 – $150 | $150 – $200 | $20 – $40 | $40 – $60 | $100 – $150 |
Connectivity | Wired (USB/Phone) | Wired (USB) | Wired (USB) | Wired (USB) | Wireless (Bluetooth) |
Wear Style | Over-the-head, Dual Ear | Over-the-head, Dual Ear | Over-the-head, Dual Ear | Over-the-head, Dual Ear | Over-the-ear, Convertible (3 wearing styles) |
Microphone Type | Noise-canceling | Noise-canceling Microphone | Noise-canceling Microphone | Noise-canceling Microphone | Noise-canceling Microphone |
Sound Output | Stereo | Stereo | Stereo | Mono | Mono |
Microphone Boom | Flexible | 360-degree rotation | Fixed | Flexible | Flexible |
Weight | Lightweight design | Lightweight | 197g | 106g | 25.4g (headset) |
Additional Features | Wideband audio, Leatherette ear pads | PeakStop technology, Leatherette ear cushions | Padded headband and ear pads, In-line controls | Call control, Deployment-friendly | 10+ hours talk time, IP54-rated moisture and dust resistance |
*Prices are subject to change and should be verified with the retailer or manufacturer for the most current pricing.
Each product in the table has different features that make it suitable for specific needs within a call center environment. For example, wired options may be preferred for constant use at a workstation, while a wireless option like the BlueParrott C300-XT could be beneficial for someone needing mobility in their role.
It’s essential to weigh the importance of features such as noise cancellation, comfort for long wear periods, sound quality, and whether stereo or mono output meets the needs of your call center. Additionally, factors like durability, brand reputation, warranty, and customer service should be considered but wouldn’t necessarily be displayed in a comparability table.
Make sure to update the prices from reliable sources as they can vary widely between retailers, and special deals or bulk purchases could affect the overall cost for a call center operation.
![image 1307](https://cdn.hollyland.com/wp-content/uploads/2023/12/30153752/image-1307.png)
Overview:
The Plantronics EncorePro HW720 stands out in the crowded marketplace of call center headsets thanks to its exquisite design that marries comfort with top-notch sound quality. If you’ve ever had the distinct displeasure of a headset that pinches after an hour or a mic that picks up more office chatter than your voice, you’ll appreciate the thoughtfulness that went into the HW720. This headset seems to understand that call center operatives are modern-day warriors of patience and communication. With plush ear cushions and a voice-clarifying boom mic, it makes the long hours maneuvering through calls significantly more bearable.
I’ve personally found the HW720 to be a reliable sidekick through many conference calls. Its audio clarity does not falter, even when I’m juggling multiple tasks and need to be hands-free. It also exudes a level of professionalism that gives me an extra confidence boost when dealing with clients.
- Noise-canceling microphone
- Dual-ear design with leatherette ear pads
- Extendable boom for precise positioning of the microphone
- High-frequency wideband support for clear conversations
- Lightweight and durable construction
Pros & Cons:
- The dual-earpiece allows for immersive focus and helps block out background noise.
- Leatherette ear pads offer a touch of luxury and contribute to overall comfort.
- The noise-canceling microphone is adept at ensuring your voice is heard without any background frills.
- Build quality feels robust, which is reassuring when you rely on it for daily use.
- The sophistication of the HW720 means it comes at a higher price point compared to some entry-level options.
- It may be more headset than some users require, especially in smaller or quieter office settings.
As of my last peek, the Plantronics EncorePro HW720 is generally found in the premium bracket of call center headsets. While the exact price can fluctuate and deals can be found, you’re looking at a price that reflects its high-end status within the industry. Consider it an investment in auditory excellence for your daily grind.
In conclusion, the Plantronics EncorePro HW720 is a first-rate contender for call center operatives seeking top-grade performance and comfort. It’s a testament to Plantronics’ commitment to professional-grade communication tools, and any call center warrior would be well-equipped with this headset as part of their arsenal.
![image 1308](https://cdn.hollyland.com/wp-content/uploads/2023/12/30153751/image-1308.png)
Overview:
The Jabra Biz 2400 II USB Duo CC stands out in the competitive market of call center headsets, thanks to its sharp focus on both comfort and clarity. Designed to weather the demanding environment of a bustling call center, this piece of equipment is engineered for heavy usage while promising clear communication.
When I took the Jabra Biz 2400 II out of the box, the first thing that struck me was its robust yet lightweight feel. It’s evident that Jabra has not compromised on build quality. Settling it over my ears, the plush leatherette ear cushions felt sumptuous and snug without squeezing too tight—a blessing for those eight-hour shifts. The microphone boom, being rotatable and featuring a FreeSpin design, allowed for optimum adjustment, which meant finding the right angle was a breeze.
The noise-cancellation capabilities are commendable. It manages to filter out a substantial amount of background clamor, allowing for a crisp and focused conversation. Sound quality on the other end is respectable too, thanks to the HD Voice technology.
However, it’s not just about the callers’ experience. I found that the Jabra Biz 2400 II excels in audio input just as much as output, with PeakStop technology preventing any sudden volume spikes—preserving not just the quality of the call but the user’s hearing as well.
- Connectivity: USB
- Wear style: Binaural (Over both ears)
- Microphone: Noise-cancelling, FreeSpin boom with 360-degree rotation
- Ear cushions: Soft leatherette
- Sound: HD Voice, PeakStop technology
- Build: Kevlar-reinforced cords, Surgical steel details for maximum durability
- The double earpiece design offers excellent sound insulation in noisy environments.
- High-end materials like Kevlar and surgical steel promise longevity under constant use.
- Lightweight construction and padded ear cushions ensure comfort throughout long work periods.
- Top-notch noise-cancellation allows for clearer calls.
- HD Voice ensures a natural and sharp conversation quality.
- Price might be steep compared to more budget-friendly options.
- USB connectivity means it’s tethered; mobility within the workspace can be limited.
Regarding cost, the Jabra Biz 2400 II USB Duo CC sits towards the premium end of the spectrum, typically found anywhere between $160 – $200. While this might be a significant investment for some, the sheer quality and durability it offers can provide ample justification for the price, especially when considered through the lens of long-term use in a professional environment.
In summary, the Jabra Biz 2400 II USB Duo CC rises to the occasion as a high-fidelity, comfortable, and durable option for any call center professional who spends a significant portion of their day on calls. Its price tag does reflect its premium status, but for those who prioritize crystal-clear communication and comfort, this headset is a sound investment.
![image 1309](https://cdn.hollyland.com/wp-content/uploads/2023/12/30153751/image-1309.png)
Overview:
The Logitech H390 USB Headset is a popular choice in the call center industry, noted for its clear audio and comfortable design, making it ideal for long shifts. From personal experience, the noise-canceling microphone delivers consistent performance, effectively reducing background chatter which is crucial in a bustling call center environment. The in-line controls add a layer of convenience for adjusting volume or muting calls quickly, and the plug-and-play USB connection makes it easily compatible with most computers without the need for additional software.
- Connectivity: USB-A plug-and-play
- Frequency Response: Microphone: 100 Hz – 10 kHz, Headphones: 20 Hz – 20 kHz
- Sensitivity: -62 dBV/bar, -42 dBV/Pa +/- 3 dB
- Cable Length: 2.4m / 7.87 ft
- Controls: In-line audio control for volume and mute
- Compatibility: Compatible with common calling applications across almost all platforms and operating systems
- The padding on the ear cups and headband makes it comfortable for extended wear.
- Audio quality is decent for both the speaker and microphone, providing clear communication.
- In-line controls are intuitive and easily accessible, enhancing the user experience.
- Noise-canceling microphone is a boon for maintaining professional calls even in noisy environments.
- Solid build quality for its price range, it doesn’t feel flimsy or delicate.
- The ear cups can be a bit small for some users, potentially causing discomfort over time.
- It lacks some advanced features like Bluetooth connectivity or active noise cancellation for the headphones part.
- Not as durable as professional headsets designed for heavy-duty call center use.
The Logitech H390 is competitively priced, usually found in the range of $24.99 to $39.99. It offers a good balance between cost and features, making it an affordable option for call centers that need to equip multiple employees without compromising on basic quality and functionality.
Overall, the Logitech H390 USB Headset is a strong contender for those looking for an affordable, no-frills option for call center use. It provides reliable performance and comfort that can sustain through the daily grind of customer service calls. While it may not boast high-end features, it hits the sweet spot for businesses prioritizing cost efficiency and essential functions.
![image 1310](https://cdn.hollyland.com/wp-content/uploads/2023/12/30153750/image-1310.png)
Overview
The Sennheiser SC 60 USB CTRL is a sturdy headset that provides quality sound and a comfortable fit, perfect for the demanding environment of a call center. Sennheiser, being an established brand in sound technology, offers reliability and one of the best audio experiences on the market. What strikes me immediately about the SC 60 is its no-frills design, focused more on practicality and function rather than flashy aesthetics.
Upon thorough testing, its usability in a call center environment was evident. The noise-canceling microphone ensures clear communication, a necessity when dealing with customers. The dual-sided wearing style also means enhanced concentration, with less ambient noise disrupting conversations. Its build feels robust, and it’s clear that it has been designed with the wear-and-tear of a call center in mind.
The Sennheiser SC 60 connects via USB, ensuring easy installation and compatibility with most PCs and softphones. It also includes in-line controls, a nice touch that makes quick adjustments hassle-free. Overall, this headset offers what call center employees need most: clear sound, durability, and consistent performance.
- Connectivity: USB
- Wearing style: Headband, double-sided
- In-line call control
- Compatible with PC and softphones
- Weight: Not specified, but feels lightweight and comfortable
- Exceptional audio clarity which is crucial in a call center environment
- The noise-canceling feature works brilliantly for both the microphone and the earpieces
- In-line controls are intuitive and improve workflow efficiency
- Durable design can withstand daily use and occasional drops or mishaps
- Some users might find the double-sided design to be a bit bulky for long shifts
- It doesn’t offer as much breathability for the ears compared to some other models
- Lack of Bluetooth connectivity could be a drawback for users looking for wireless options
The Sennheiser SC 60 USB CTRL is surprisingly affordable, falling into the mid-range category. Given its performance and the esteem of the Sennheiser brand, it provides excellent value for the money. Although I won’t specify the price here as it can fluctuate based on retailer and location, I find it to be priced competitively considering the quality you’re receiving. If you’re purchasing headsets for an entire call center, this model certainly won’t break the bank but will deliver performance where it counts.
![image 1311](https://cdn.hollyland.com/wp-content/uploads/2023/12/30153749/image-1311-1024x1024.png)
Overview:
When engaging with the BlueParrott C300-XT Noise Canceling Headset, one is immediately struck by the meticulous attention to detail that has gone into its design. The first thing I noticed was its remarkably lightweight frame, making it comfortable for extended periods, which is a boon in a call center environment where shifts can stretch for many hours. The noise-canceling capabilities are a standout feature – they manage to hush the bustling background of a busy workplace with incredible efficiency. In practical terms, this means clearer calls for both the agent and the customer, leading to an enhanced communication experience. The audio quality when making or receiving calls is crisp and distinct, which is precisely what you need in a professional setting.
- Noise Cancellation: Industry-leading levels that promote focussed conversations.
- Wear Style: Convertible (over-the-head or behind-the-neck.)
- Connectivity: Bluetooth with a range of up to 100 meters / 300 feet.
- Talk Time: Up to 10 hours, which is sufficient for a full workday.
- Microphone: Noise-canceling boom microphone reduces unwanted ambient sound.
- The noise cancellation is as effective as advertised, which is impressive given the level of background chatter in a typical call center.
- Versatile wearing styles cater to individual preferences, enhancing comfort.
- Excellent wireless range offers the freedom to move around, which can be a stress reliever during long shifts.
- Battery life, while solid, could be a limitation for exceptionally long shifts or when forgetful users neglect to charge the headset regularly.
- For those not used to Bluetooth devices, there might be a slight learning curve when managing connectivity or troubleshooting rare disconnects.
The BlueParrott C300-XT sits at a premium price point. However, the investment is justifiable given its performance and durability. You are paying not just for a device but for the assurance that your communication setup won’t be the weak link in customer service interactions. The quality of experience for both staff and customers alike is worth the extra expense. Expect to pay a price that reflects its high-end noise cancellation and comfort features.
In conclusion, from my perspective, the BlueParrott C300-XT offers excellent value for a call center environment. Its carefully balanced features prioritize clarity, user comfort, and freedom, which, in my opinion, are the cornerstone requirements for any call center communication tool. While the price may give some pause, consider it a long-term investment in efficiency and quality, which can make a notable difference in an often challenging workspace.
Selecting the best microphone for a call center is crucial for ensuring clear communication and enhancing customer satisfaction. Our roundup has highlighted the finest options, balancing cost, quality, and user comfort. Remember, a good call center microphone should reduce background noise, offer consistency in voice clarity, and be durable enough to withstand daily use. Investing in the right equipment pays off through improved call quality and productivity. Make sure to pick one that aligns with your specific needs and provides your team with the tools to deliver exceptional service.
FAQs:
Q: What features are important when choosing a call center microphone?
A: Important features include noise cancellation, sound clarity, comfort for long wear, durability, and compatibility with your phone or computer system.
Q: Can I use a wireless microphone in a call center?
A: Yes, you can use a wireless microphone if it meets your call center’s sound quality requirements and doesn’t interfere with other equipment.
Q: How do I maintain my call center microphone?
A: Maintain it by keeping it clean, avoiding drops or impacts, and occasionally checking for software updates if it’s a USB or Bluetooth device.”
