New Product Coming
DAYS
HRS
MINS
SECS
7 Best Wireless Microphones For Live Vocals in 2023
Wireless microphones have become essential for live performances, especially for vocalists who need freedom of movement. The quality of a wireless microphone is crucial for a singer’s performance, as it can significantly impact the clarity and projection of their voice.
Choosing the best wireless microphone for live vocals can be daunting, with many options available on the market. But don’t worry, we’ll review some of the top wireless microphones currently available for live vocals in this article.
Whether you are a professional singer or just starting, this article will provide valuable insights to help you choose the best wireless microphone for your singing needs.
What qualities should you look for when choosing a wireless microphone for mobile?
There are various factors to consider when selecting a wireless microphone for live singing. Here are some essential features to look for:
  1. Frequency spectrum: To catch the entire spectrum of your speech, make sure the microphone has a wide frequency range.
  2. Frequency Response: Look for a microphone with a balanced frequency response that does not favor any one frequency range.
  3. Wireless Range: The wireless range of the microphone is critical for moving freely on stage without losing the signal.
  4. Battery Life: Check the microphone’s battery life to guarantee that it will survive the duration of your performance.
  5. Noise Reduction: To remove unwanted background noise, use a microphone with noise reduction functions.
  6. Compatibility: To avoid compatibility difficulties, ensure the microphone is compatible with your existing sound system.
With these features in mind, you can select the best wireless microphone for live vocal performances.
Here’s our list of the best Wireless Microphone For Live Vocals:
1. Hollyland Lark M1
2. Hollyland Lark 150
3. AKG WMS470
4. Samson Go HXD2
5. Shure Beta 58A
6. Synco G2 A2
7. Behringer ULM302MIC
1. Hollywood Lark M1
The Hollyland Lark M1 wireless microphone is an ideal choice for live singing, with a small and lightweight design allowing for easy mobility on stage. The dual-channel receiver perfectly syncs with the transmitters, allowing continuous audio recording. The microphone has a sturdy storage and charging case and a battery life of up to 32 hours.
The Lark M1 is designed to clip onto garments, allowing you to connect it to any portion of your outfit. This function is ideal for live performances since it will enable you to move freely without sacrificing audio quality. The microphone has a frequency response of 20Hz to 20kHz, allowing it to capture the whole spectrum of your speech.
The self-adaptive audio processing algorithm reduces noise, removes unnecessary background noise, and makes your voice shine.
Hollywood Lark M1
NameHollywood Lark M1
Price$149
Weight37g
Connector type3.5mm TRS connector
Polar patternOmni-directional
Battery life8 hours, up to 32 hours with charging case
  • 656 feet long-range transmission.
  • One-click noise cancellation function, which reduces unwanted background noise for better audio quality
  • Three-level volume preset, LC3 Codec, and enhanced 48kHz/16-bit sampling rate
  • The 3.5mm TRS connector may not be compatible with some devices
Hollyland Lark M1 is an excellent wireless microphone for live vocals that offers impressive features and reliable performance, making it an ideal choice for singers and performers alike.
Just weighing around 20.5 grams, the Hollyland Lark 150 is your wireless microphone companion that is a perfect device to change your vocal game. Imagine a mic so light and small that it feels like a coin resting on your shirt’s collar. So, no more worries about your droopy collar ruining your personality and confidence on stage. The Lark 150 is made to be your audio friend, sitting pretty invisible when worn to your collar. Well, yes, that’s 150’s design – portable and convenient.
However, don’t get confused by its size since this microphone offers a wide wireless range of 100 meters. Whether you’re presenting or singing your favorite tunes on the stage, the Hollyland Lark 150 ensures your vocals are heard at every nook and corner with detailed audio. Moreover, this wireless microphone kit eases you from the complex setups as the systems get paired in less than three seconds.
8iJ9 wmolHtMGw3MzTm6zA96mEw8e2Yo83dfjBOvPoaG24EQ9AoOzTNh vyDhh6j6U0eS76sR2KWSYLSsg0uQg2DMqE6BCqFsK4on9QhgIu40hQEz8XqQLE VYIFzYzrZOtNPKi5etqasNYPhbLjZq8
NameHollyland Lark 150
Price$199
WeightTransmitter- 20.5 grams and Receiver- 51 grams
Connector typeUSB and 3.5mm
Polar patternOmnidirectional
Battery life4.5 hours
  • The overall build quality is quite rigid
  • All essential accessories are included in the package
  • Due to the long transmission range, this mic gives users the freedom to move around the stage
  • Incredibly lightweight and small, making it simple to use and carry without overburdening yourself
  • A very few users report that this microphone kit sometimes randomly changes recording levels
Sugar on the cream, the Hollyland Lark 150 is a symbol of brilliance, having built-in omnidirectional microphones, LED indicators, and a lapel mic jack. The integrated microphones deliver superb audio quality, bringing this kit above all other wireless mic brands. Plus, the battery life is good enough to complete your speech, song, or presentation, as each transmitter runs for up to 4.5 hours when fully charged.
3. AKG WMS470
The AKG WMS470 is a high-grade wireless microphone system built for live performances. It features a tiny and lightweight bodypack transmitter and a dual-channel receiver that can handle two microphones simultaneously, making it ideal for usage by multiple performers.
The cardioid polar pattern of the microphone separates the performer’s voice from background noise by picking up sound from the front and sides while rejecting sound from the back, making it perfect for use on stage.
With a range of up to 100 meters and a battery life of up to 14 hours, the AKG WMS470 offers exceptional sound quality with a frequency response of 35 Hz to 20kHz and a dynamic range of 120 dB.
AKG WMS470
AKG WMS 470
NameAKG WMS470
Price$799
Weight340g
Connector typeXLR and 1/4 inch jack
Polar patternCardioid
Battery life14 hours
  • Cardioid polar pattern that isolates the performer’s voice from other sounds in the environment.
  • Up to 100 meters of range, providing ample coverage for most live performances.
  • The AKG WMS470 is relatively expensive compared to other wireless microphone systems
  • The microphone system is slightly heavier than other options
Overall, the AKG WMS470 is a high-quality wireless microphone system with excellent sound quality and reliable performance, making it an ideal choice for live performers who demand the best.
4. Samson Go HXD2
The Samson Go HXD2 wireless microphone is a great option for live singing, with a compact design that makes it easy to carry on stage. The dual-channel receiver ensures seamless audio recording by perfectly syncing with the transmitters. The microphone has a sturdy storage and charging case and a battery life of up to 20 hours.
The Go HXD2 is designed with a magnetic clip that easily attaches to clothing, providing flexibility and freedom of movement while maintaining optimal audio quality. It also has a 24-bit depth and a sample rate of 48kHz, resulting in superior sound quality.
Samson Go HXD2
Samson Go HXD2
NameSamson Go HXD2
Price$59.95
WeightApproximately 24g
Connector typeWireless, USB-C
Battery lifeUp to 20 hours
  • 100 feet range transmission, making it ideal for small to medium-sized venues.
  • Easy compatibility with Windows and Mac computers through USB-C connection.
  • The microphone may not be compatible with some devices
Overall, the Samson Go HXD2 is an excellent wireless microphone for live singing, providing outstanding features and reliable performance, making it an ideal choice for singers and performers.
5. Shure Beta 58A
The Shure Beta 58A wireless microphone is a robust and reliable option for live vocals, featuring a super-cardioid polar pattern that allows for superior sound isolation. The dual-channel receiver ensures seamless audio recording, and the microphone has a sturdy construction with a battery life of up to 14 hours.
Designed with a rugged grill and advanced pneumatic shock mount system, the Beta 58A is ideal for use on stage, with minimized handling noise and uninterrupted performance. The microphone has a frequency response of 50Hz to 16kHz, capturing a wide range of vocal tones with clarity and precision.
Shure Beta 58A
Shure Beta 58A
NameShure Beta 58A
Price$169
Weight~278g
Connector typeXLR
Polar patternSupercardioid
Battery lifeUp to 14 hours
  • Excellent sound isolation and superior vocal clarity, even in noisy environments.
  • Rugged construction that withstands the rigors of live performances.
  • Advanced shock mount system that minimizes handling noise.
  • The microphone’s weight may be challenging for performers who prefer lighter options.
  • The XLR connector may not be compatible with some devices requiring other audio input types.
The Shure Beta 58A wireless microphone is an excellent option for live vocals. It provides reliable performance, superior sound quality, and advanced features, making it an ideal choice for singers and performers.
6. Synco G2 A2
The Synco G2 A2 wireless microphone is a professional-grade option for live performances, with a compact and lightweight design that makes it easy to carry. The dual-channel receiver provides seamless audio recording, and the microphone has a sturdy construction.
Moreover, the Synco G2 A2 boasts advanced digital signal processing technology that reduces unwanted noise, ensuring clear and professional-grade audio quality. The microphone has a 24-bit depth and a sample rate of 48kHz, resulting in superior sound quality.
Synco G2 A2
Synco G2 A2
NameSynco G2 A2
Price$169
Weight39g
Battery lifeUp to 8 hours
  • 30 meters range transmission, making it ideal for small to medium-sized venues.
  • The microphone may not be compatible with some devices that do not support USB-C connectivity.
The Synco G2 A2 is an excellent wireless microphone for live performances, providing outstanding features and reliable performance, making it an ideal choice for singers, presenters, and performers.
The Behringer ULM302MIC wireless microphone is a versatile and affordable option for live performances, with a sleek and lightweight design that makes it easy to handle. The dual-channel receiver provides seamless audio recording by perfectly syncing with the transmitters.
The ULM302MIC is designed with a handheld microphone and a robust transmitter that can withstand the rigors of live performances. The microphone has a frequency response of 50Hz to 18kHz, capturing a wide range of vocal tones.
Moreover, the Behringer ULM 302 MIC features advanced digital wireless technology, ensuring crystal-clear sound quality with low latency. The microphone has a 24-bit depth and a sample rate of 48kHz, resulting in superior sound quality.
Behringer ULM302MIC
Behringer ULM302MIC
NameBehringer ULM302MIC
Price$169
WeightApproximately 390g
Connector typeUSB
Battery lifeUp to 24 hours
  • 300 feet range transmission, making it ideal for large venues and outdoor events.
  • Affordable price without sacrificing audio quality.
  • The handheld design may limit the freedom of movement compared to a lapel or clip-on microphone.
Overall, the Behringer ULM302MIC is an excellent wireless microphone for live performances, providing outstanding features and reliable performance for singers and presenters.
Wireless microphones are an essential tool for singers, presenters, and performers who need high-quality audio for their live vocals.
There are various options available on the market, and it can get confusing for prospective buyers to make a decision. This article highlights the top 7 best wireless microphones for live vocals that offer excellent sound quality.
To take your musical performances to the next level, we recommend the Hollyland Lark M1 Compact Wireless Mic System and Hollyland Lark 150. Equipped with these mics, you can be sure to record all your live vocals at an affordable price.
FAQ:
Q: How do I choose a wireless microphone for live vocals?
A: When choosing a wireless microphone for live vocals, consider factors such as frequency range, signal-to-noise ratio, battery life, and durability.
Q: How far can a wireless microphone for live vocals reach?
A: The range of a wireless microphone for live vocals can vary depending on factors such as the frequency band and obstacles. Generally, most wireless microphones have a range of up to 300 feet.
Q: Can I use a wireless microphone for live vocals outdoors?
A: Yes, you can use a wireless microphone for live vocals outdoors. It’s also important to consider the environmental factors that may affect the wireless range of the microphone.
Q: How do I set up a wireless microphone for live vocals?
A: To set up a wireless microphone for live vocals, connect the receiver to your sound system, turn on the microphone and receiver, and adjust the levels on your soundboard. Make sure the microphone is positioned correctly and test it before the performance.
Facebook
Twitter
Pinterest
Related Posts
