How Does the iPhone Share Audio Without AirPods
The best music-listening experience is sharing songs or movies with someone else. Apple’s classical “Audio Sharing” feature allows you to share favorite music and connects families without needing AirPods. Audio Sharing is a built-in technology on Apple’s latest versions, and you will share with wireless headphones.
Audio Sharing enables you to create a shared listening experience by connecting to other iPhones, iPads, or iPods. However, pairing your headphones or iPhones before enjoying music is mandatory. So, this guide will develop a complete understanding and teach you to share audio without AirPods.
Share Audio lets you listen to your favorite music or movies with multiple headphones. Actually, you don’t need AirPods to share audio, this feature works with any devices equipped with W1 or H1 advanced chip technology. IPhone’s cutting-edge technology is the beacon of creating memories with its shared listening experience.
Furthermore, due to the compatibility issues of the iPhone or headphones, it’s essential to understand how to connect them. And “Audio Sharing” enhances the capabilities with its ability to connect up to two wireless devices. Therefore, you can connect other (non-AirPods) Headphones to share audio by following the step-by-step guide.
Steps to Share Audio Without AirPods
Step 1- Connect Bluetooth Headphones
  • First, connect your Beats headphones to your iPhone via Bluetooth
  • Pair a second set of headphones on your other smartphone
  • After clicking, open your music app and start playing the song or movie
Step 2- Open Share Audio
image 118
  • Go to the “Control Center” of your iPhone or from the app you are listening to or from your device’s lock screen.
  • Then tap on the “Airplay” button from the top-right corner of the pop-up window.
  • After that, click on the “Share Audio” button.
Step 3- Pairing the headphones
image 119
  • Bring your other phone close and click on the “Join” button from the other phone.
  • Wait for a few seconds, and it will start functioning properly
  • When the headphone’s name appears on the screen, tap “Share Audio” and seamless music experience.
Note: Before pairing the devices, you must touch the phones together for a quick, seamless pairing solution.
If the second person doesn’t have their phone with them or the battery dies, they can still Audio Share on one phone. For this, you must follow the hereunder enlisted simple steps:
  • Click on the power button from the compatible headphones set, and a dialog will pop up on your smartphone
  • Tap on the “Connect” and second headphones will pair with your device
  • Click open the “AirPlay” menu from the “Control Center” of the app or your iPhone
image 120
  • Then click to add the second set for “Share Audio” and start listening
  • During this, you can control the volume from a single smartphone or your respective headphones
In addition, the second way is to pair their headphones with your device and select both pairs in your settings as primary options for audio streaming.
This feature of audio sharing is incredible when you want to watch a movie together while traveling. It’s easy to pair with other iPhones or headphones, but both devices must be compatible for a seamless experience.
Audio Sharing is an advanced feature that depends on the availability and compatibility of connecting devices. Apple allows several other headphones besides AirPods for audio sharing and developing memories together. However, it’s essential to understand the compatibility issues for seamless musical entertainment.
Compatibility
The first and foremost important thing is to have compatible devices, and the Audio Sharing feature works on iPhone 8 or above. And ensure that your iPhone has iOS 13, or you must update to enjoy the audio-sharing experience.
Besides AirPods, you can audio share on your iPhone with wireless headphones because Apple only allows limited devices. So, the devices compatible with this are listed hereunder:
  • AirPods Max
  • AirPods Pro (1st generation) and later
  • AirPods (1st generation) and later
  • Powerbeats
  • Solo Pro
  • Powerbeats Pro
  • Powerbeats3 Wireless
  • Beats Solo3 Wireless
  • Beats Studio3 Wireless
  • BeatsX
  • Beats Flex
  • Beats Fit Pro
So, before “Audio Share,” ensure you use compatible devices running on the latest Bluetooth versions. Furthermore, you can simultaneously share audio with only two compatible devices to a single phone and have to disconnect to connect to another device.
How to Control Audio Sharing on iPhone
After connecting, you can share and control your musical experience from your phone or connected headphones. Audio sharing is an advanced feature, and it’s essential to have complete command by learning and taking over the controls. So, you can control your audio by adjusting the volume or changing the track you are listening to.
The iPhone sharing the audio will have complete control over the selection of music, and it cannot be changed from another phone. Furthermore, the volume of both headphones is set at the same level, but you can change it accordingly by following the method:
image 121
  • Access the “Control Center” from your iPhone and drag the volume slider.
  • With this, you can change the volume or pass the music for either set of headphones.
Besides this, you can change the audio level of your headphones, but only that headphone volume will be affected.
Stop the Audio Share
image 122
  • You can also stop listening by opening the “Control Center” from your iPhone, lock screen bar, or the app you are listening to.
  • Then tap on the “AirPlay” button from the top-right corner.
  • After that, tap the “Checkmark” icon next to the headphones.
Note: The second headphone will automatically disconnect when you click the checkmark to stop sharing the music. So, after sharing stops, you must reconnect the headphones by following this guide for a seamless audio experience.
Also, both users can control the volume coming through Beats headphones from their respective smartphones.
Apple revolutionizes the musical industry with its audio-sharing technology that brings people together. AirPods are undoubtedly popular with their seamless capabilities, but only some have access to similar earbuds. Therefore, it allows users to Share Audio without AirPods via headphones, but they must be compatible.
With audio sharing, the iPhone provides unlimited opportunities to cherish the moments and share the joy. So, knowing how to connect and listen to your favorite with your loved ones will make incredible memories. Therefore, the abovementioned guide provides complete details to connect and control your unlimited shared musical experience.
Can I share audio with non-Apple headphones?
Due to Apple’s compatibility, the Audio Sharing feature only works with AirPods and Beats headphones. This compatibility issue arises due to specific iOS versions and particular W1 and H1 chips that make it compatible with other devices. Furthermore, not all Apple products or Beats are equipped with W1 or H1 technology, so they do not support Audio Sharing.
However, some of the Samsung Galaxy’s newer models are equipped with Bluetooth 5.0 technology that supports dual Audio Sharing. To connect with another device, you can follow the guide above.
How many iPhones can you share audio with?
There is a limit when using the “Share Audio” feature because it only works with two compatible iPhones. Besides this, you can connect two pairs of compatible AirPods or Beats headphones, and you must disconnect them before joining other devices.
Furthermore, compatibility issues limit its functionality, and you must touch the devices before the pairing. It works on Bluetooth or Wi-Fi, so connecting devices must be nearby.
Why Audio Share is not working correctly on my iPhone?
The most likely reason Audio Share isn’t working correctly on your iPhone is that your device isn’t compatible. For this feature, it’s recommended that you use an iPhone 8 with iOS 13, and it only works with AirPods or Beats headphones. However, if the problem continues even after using compatible devices, follow the guidelines for a seamless audio-sharing experience.
  • Due to software glitches or bugs, the app you are listening to will not function properly, so force quit and try using a different app.
  • The simplest yet effective solution is “Restarting” both or any of the problem-causing devices.
  • Ensure you are pairing the headphones with the latest Bluetooth 5.0 technology.
Facebook
Twitter
Pinterest
Picture of John Doe
John Doe
Related Posts
