• Studio-Quality Audio
    With MaxTimbre
    Technology
  • 820ft (250m) LOS Range
    8GB On-Board Storage
    for 14-Hour Backup
    Recording
  • Magnetic
    Professional Environmental
    Noise Cancellation (ENC)
The LARK MAX is an all-in-one wireless lavalier microphone system with industry-first MaxTimbre Mic technology and advanced ENC technology providing an unparalleled crystal-clear sound. The transmitter has 8GB of built-in memory, providing up to 14 hours of backup recording. It is perfect for interviewing, vlogging, podcasting, electronic field production, online teaching, and any audio recording applications requiring high-quality audio pickup and a peace-of-mind audio backup solution.
with MaxTimbre Mic Technology
With its MaxTimbre Mic technology, the LARK MAX sets a new standard for capturing every detail and nuance with stunning clarity. Boasting a list of impressive technical specifications: 48kHz sampling rate, 24-bit bit depth, 70 dB SNR, and 128 dB max SPL.
Industry-First Mic Technology
MaxTimbre
MaxTimbre Mic technology is a multilayer membrane microphone design that optimizes voice recording for crisp, clear results. The multilayer acoustic structure effectively eliminates unwanted resonances. It enhances performance with a durable mesh of superior wind-proof and vibration-isolation features.
High-Sensitivity
Omnidirectional Microphone
48kHz/24-bit
The LARK MAX high-sensitivity omnidirectional 48kHz/24-bit microphone records full-range audio with incredible precision, clarity, and rich detail.
High Signal-to-Noise Ratio
70 dB
The LARK MAX SNR is 70 dB, which is crucial for recording in quiet environments.
Max Sound Pressure Level (SPL)
128 dB
The LARK MAX stands up to 128 dB of SPL, and its 98-106 dB dynamic range significantly reduces audio distortion when recording in complex environments.
Note: The maximum SPL is based on laboratory testing results, with the transmitter input gain set to the lowest level. For optimal recording results, it is recommended to place the transmitter at a proper distance from the audio source.
Advanced Technology
DSP
The LARK MAX utilizes Digital Signal Processing (DSP) technology to significantly enhance audio signal quality and reduce unwanted noise and interference.
Professional ENC
Environmental Noise Cancellation
The LARK MAX utilizes advanced ENC technology to detect and minimize surrounding noise, ensuring the audio quality remains crystal clear and distortion-free, even in loud recording environments. It is user-friendly, allowing you to easily turn the ENC mode on or off from the transmitter or receiver.
On-Board Storage for 14-Hour Backup Recording
The LARK MAX transmitter also serves as a standalone recorder with built-in 8GB of storage. Record up to 14 hours of uncompressed and lossless WAV files. The internal recording files are stored in the transmitter. You can turn on the Auto Record mode on the receiver to activate the transmitter’s internal recording feature for extra audio safety, ensuring that you won’t miss any important moments.
14 Hours
Backup Recording
8GB
Memory
Ultra-long
22-Hour Battery Life
The LARK MAX is designed with a compact charging case, so you can enjoy virtually unlimited recording adventures without worrying about battery life. The transmitter’s operation time is about 7.5 hours and can reach up to 22 hours with a fully charged charging case. The receiver can operate for up to 9 hours, and it can be charged and used at the same time.
Note: The data provided above is based on laboratory testing results.
Wide Device Compatibility
Enjoy teaming the LARK MAX with mobile devices, cameras, or computers.
appdownload
wide 1 wide 2
The 3.5mm output interface makes it compatible with many camera types — DSLR cameras, mirrorless cameras, action cameras, camcorders, and others. To connect the receiver to a camera, just use the 3.5mm TRS to 3.5mm TRS cable.
Simply connect the receiver to a mobile phone with the included MFi-certified USB-C to Lightning cable or USB-C to USB-C cable or the optional 3.5mm TRS to 3.5mm TRRS cable. Achieve real-time audio playback on your phone speaker without the need to unplug the receiver from your device for an immediate audio quality check.
If your phone’s volume button can control recording, you can easily use the power button on the transmitter of LARK MAX to start or stop recording smoothly.
The LARK MAX also supports USB Audio Class (UAC) standards and can work as a sound card sending high-quality audio sources to your computer via a single USB cable.
820ft (250m)
Stable Transmission with AFH Technology
The LARK MAX provides an ultra-long wireless line-of-sight (LOS) range of up to 820ft (250m) with dual high-gain antennas. It also adapts advanced adaptive frequency hopping (AFH) technology to effectively prevent signal drops and ensure a seamless audio recording experience.
Note: The LOS range of 820ft (250m) is measured in an unobstructed outdoor environment free of interference.
Convenient
Magnetic Design
Each transmitter comes with a convenient back clip and a clip magnet. The transmitter weighs approximately 33g (1.16oz) and can easily be attached to any garment and other objects via the integrated back clip or the clip magnet.
User-friendly Design
The LARK MAX works perfectly with various recording devices and is paired and ready for use out of its charging case. Addressing different audio recording preferences with its flexible gain control allows you to precisely tailor the audio volume for an outstanding user experience.
Color AMOLED
Touchscreen
The colorful and vivid AMOLED touchscreen on the receiver allows you to adjust transmitter settings and provides a real-time visual check.
Quick Control
Knob
You can customize different settings quickly with the control knob.
list2 list2
On-Screen
Home Button
A single tap easily accesses the quick settings interface or returns to the previous interface.
list icon2
list3 list3
Skin-like
Comfortable Touch
The LARK MAX has a sleek and stylish appearance, giving it a warm, comfortable, and natural feeling when touched.
Professional Functions
Recording Modes
Select the most suitable audio recording mode: mono, stereo, or safety track for recording security and more flexibility in post-production.
  • Mono
  • Stereo
  • Safety Track
EQ Settings
Hi-Fi
The Hi-Fi function provides high-quality audio recording with utmost precision and accuracy.
EQ Settings
Low Cut
The Low Cut function removes low frequencies of the audio signal, eliminating low-end rumble.
EQ Settings
Vocal Boost
The Vocal Boost function reduces environmental noise and improves voice intelligibility, making a more pleasant and crystal-clear recording experience.
What’s Included
  • Transmitter
    include color
  • Transmitter
    include color
  • Receiver
    include color
  • Charging Case
    include color
  • USB-C to
    USB-A Cable
    include color
  • 3.5mm TRS to
    3.5mm TRS Cable
    include color
  • USB-C To
    USB-C Cable
    include color
  • USB-C To
    Lightning Cable
    include color
  • Clip Magnet
    include color
  • Furry Windshield
    include color
  • Storage Bag
    include color
  • Quick Guide
    include color
  • Warranty Card
    include color
  • Packing List Card
    include color
  • Transmitter
    include color
  • Receiver
    include color
  • USB-C to
    USB-A Cable
    include color
  • 3.5mm TRS to
    3.5mm TRS Cable
    include color
  • USB-C To
    USB-C Cable
    include color
  • USB-C To
    Lightning Cable
    include color
  • Clip Magnet
    include color
  • Furry Windshield
    include color
  • Storage Bag
    include color
  • Quick Guide
    include color
  • Warranty Card
    include color
  • Packing List Card
    include color
Specifications
  • Dimensions Approx. 48.5mm x 30.3mm x 19.37mm
    (1.9″ x 1.2″ x 0.76″)
  • Weight Approx. 33g (1.16oz)
  • Transmission Range Up to 820ft (250m) for LOS/197ft (60m) for NLOS
  • Modulation Mode GFSK
  • EIRP <20dBm
  • Operating Frequency 2.4GHz
  • Battery Type RoHS-compliant LiPo
  • Battery Capacity 300mAh
  • Battery Voltage 3.87V
  • Battery Energy 1.161Wh
  • Charging Temperature 0° C to 45° C
  • Operating Temperature –20° C to 45° C
  • Charging Time <2 hours
  • Operating Time Approx. 7.5 hours
  • Recording Time Approx. 14 hours
  • Recorded Audio Format 48 kHz/24-bit WAV
  • Mic Polar Pattern Omnidirectional
  • Mic Sensitivity –36dBFS±1dB@1 kHz, 94dB SPL
  • Input Dynamic Range 98dB (Default)/106dB (Max)
  • Frequency Response 20 Hz–20 kHz (Low Cut disabled)
  • Signal-to-Noise Ratio 70dB
  • Sound Pressure Level 120dB SPL (Default)/128dB SPL (Max)
  • Equivalent Noise 24dBA
Note: The transmission range is measured in an unobstructed outdoor environment free of interference. The frequency band may vary depending on different countries.
  • Dimensions Approx. 58mm x 40.83mm x 23.17mm
    (2.3″ x 1.6″ x 0.9″)
  • Weight Approx. 60g (2.1oz)
  • Touchscreen 1.1″ AMOLED
  • Touchscreen Resolution 126 x 294 pixels
  • EIRP <20dBm
  • Operating Frequency 2400MHz–2483.5MHz
  • Battery Capacity 490mAh
  • Battery Energy 1.896Wh
  • Operating Time Approx. 9 hours
  • Dimensions Approx. 115mm x 46mm x 63mm
    (4.5″ x 1.8″ x 2.5″)
  • Weight Approx. 193.5g (6.8oz)
  • Battery Capacity 2800mAh
  • Battery Voltage 3.85V
  • Battery Energy 10.78Wh
  • Max Charging Times Approx. two times of charging for 2 TX and 1 RX
