Dual HDMI 300ft (100m) Wireless Video Transmission System
300ft (100m)
Transmission Range
0.1s
Low Latency
Real-Time App
Monitoring
HDMI IN
& LOOPOUT
Thumbwheel
Switch
Side OLED
Display
Featuring an external antenna design, the Mars 300 Pro provides excellent signal stability for smooth wireless video transmission. With a front mount interface and heat dissipation holes at the side, the unit is compact and sleek for easy storage, setup, and use.
The transmission distance of up to 300ft (100m) supports a wider working range. The 0.1s ultra-low latency ensures instant video transmission, achieving more efficient team collaboration.
The thumbwheel switch integrates easy menu navigation and settings configuration, and the intuitively designed button delivers a user-friendly control experience.
The Mars 300 Pro can be charged using a portable power bank via the USB-C interface, a DC adapter, or an NP-F battery. The options and flexibility provide assurance of uninterrupted wireless video transmission.
Both the transmitter and receiver are designed with two HDMI interfaces for supporting more than one device connection with simultaneous video input and output. One of the HDMI interfaces on the transmitter is LOOPOUT, which supports direct video output from the camera to a small monitor for the cameraman.
The high-definition side OLED display provides at-a-glance status for signal strength, remaining battery life, and active channel. Whether the device is installed vertically or horizontally, the display screen will face you, and you can see what is displayed without lowering the device.
Team monitoring and collaboration are made easier and more cost-effective by installing the HollyView app on your mobile device. The app also supports additional functions such as 3D LUTs, focus peaking, zebra pattern, and zooming.
The transmitter comes with built-in antennas to simplify relocation and installation.
The transmitter comes with detachable antennas and an anti-impact design. With a stronger signal and extra protection, this package is suitable for more complex shooting environments.
The transmitter comes with an HDMI LOOPOUT interface for video monitoring on or near the camera.
To ensure the best device performance, firmware upgrade can be made directly through the HollyView app. It is that easy.
Transmitter x1
Receiver x1
Expansion Accessory x1
Cold Shoe x1
USB-A to USB-C Cable x1
User Manual x1
Transmitter x1
Receiver x1
Transmitter Antenna x3
Cold Shoe x1
User Manual x1
Transmitter x1
Cold Shoe x1
User Manual x1
HDMl IN (Type A Female)
HDMI LOOPOUT (Type A Female)
2 Antenna lnterfaces (RP-SMA Male)
USB-C
USB-C Supply: 5V/2A
Battery Supply: 5-12V DC
<11W
136g (4.8oz)
(L x W x H): 110mm x 61mm x 22.8mm (4.3" x 2.4" x 0.9")
(Battery Plate Excluded)
HDMI:
480p60
576p50
720p50/59.94/60
1080i50/59.94/60
1080p23.98/24/25/29.9/30
1080p50/59.94/60
5GHz
OFDM
Maximum 21dBm
0.1s
20MHz
HDMI OUT (Type A Female)
USB-C
USB-C Supply: 5V/2A
<4W
128.5g (4.5oz)
HDMI:
480p60
576p50
720p50/60
1080i50/60
1080p24/25/30
1080p50/60
5GHz
OFDM
–80dBm
0.1s
20MHz
