0.07s
Low Latency
450ft(150m)
LOS Range
12Mbps
Data Rate
SDI & HDMI
Dual Ports
Flexible Monitoring
Options
Smart Channel
Scan
Multiple Fan
Modes
Integrated
Cold Shoe
Mars 400S Pro II is a powerful video transmission device with several remarkable features. It offers a transmission range of up to 450ft (150m) and achieves a low latency of just 70ms. Additionally, Mars 400S Pro II is equipped with SDI+HDMI dual interfaces, supports multi-receiver setups, and allows monitoring through the HollyView App.
Supports 12 Mbps data rate, enabling high-definition video transmission and delivering clear, refined image quality with rich details.
Transmission Range
Latency
Mars 400S Pro II raises the bar with an incredibly low latency of just 70ms. It outperforms
Mars 400S Pro by reducing latency by 30% and providing a stable signal
up to 450ft. This ensures exceptional high-definition image quality and an immersive
low-latency experience.
Furthermore, Mars 400S Pro II is compatible with Mars 400S Pro, allowing them to be paired
and used together.
Note: The LOS range of 450ft (150m) is based on interference-free laboratory measurements.
Equipped with both SDI and HDMI interfaces, Mars 400S Pro II provides enhanced device compatibility and convenient connections to various types of equipment. Whether it's a DSLR camera or a professional film camera, Mars 400S Pro II can fulfill your connectivity requirements.
Upon startup, Mars 400S Pro II automatically selects the best frequency channels. Additionally, channel scanning can be conducted using the receiver or the HollyView App, providing a visual representation of signal interference levels at each frequency. Allows for the swift identification of the most suitable frequency.
Note: Smart channel scanning with HollyView App
Mars 400S Pro II offers flexible solutions to meet monitoring needs, including team collaboration, multi-crew monitoring, and multi-member cooperation.
1 Transmitter X 2 Receivers
1 Transmitter X 1 Receiver & 2 APP
1 Transmitter X 4 APP
Mars 400S Pro II is equipped with a three-speed fan adjustment feature (Auto, Low Speed, Off). Its intelligent cooling design allows it to perform optimally in various usage scenarios by reducing device temperature and ensuring stable signal transmission.
The device automatically adjusts the fan speed based on its temperature, ensuring effective heat dissipation.
The fan operates at the lowest speed, reducing noise generation. This mode is suitable for environments where low noise levels are required.
The fan is completely turned off, making it suitable for scenarios that require absolute silence.
Integrated with a cold shoe featuring a 1/4-inch threaded cold shoe simplifies the installation process. Simply connect the cold shoe of the Mars 400S Pro II to the cold shoe slot on the device, without the need for any cumbersome additional installation steps.
Transmitter x1
Receiver x1
Antenna x5
DC Adapter x1
User Manual x1
Warranty Card x1
Receiver x1
Antenna x3
DC Adapter x1
User Manual x1
Warranty Card x1
HDMI Input (Type A Female)
SDI Input
2* Antenna Interfaces (RP-SMA Male)
DC Input
USB Type-C
DC Power Input: 6-16V
USB Type-C Power Supply: 5V/2A
Battery Power Supply: 6-16V DC
<11W
206g
(L*W*H): 110*72*33.5mm
(The Battery Plate Exclude)
HDMI:
720p50/59.94/60
1080i50/59.94/60
1080p23.98/24/25/29.97/30
1080p50/59.94/60
SDI:
1080p60/59.94/50(Level A)
1080p60/59.94/50(Level B)
1080i60/59.94/50
1080p30/29.97/25/24/23.98
1080psf24/23.98
1080psf30/29.97/25
720p60/59.94/50
5GHz
≤21+/-1.5dBm
HD Mode: 70ms
Focus: 56ms
20MHz
HDMI Output (Type A Female)
SDI Output
DC Input
USB Type-C
<7W
206g
HDMI:
720p50/60
1080i50/60
1080p24/25/30
1080p50/60
SDI:
1080p60/50(Level A)
1080i60/50
1080p30/25/24
1080psf24
720p60/50
5GHz
-80dBm
HD Mode: 70ms
Focus: 56ms
20MHz
