banner pc banner pe
1,100ft (350m) Full-Duplex ENC Wireless Intercom Headset System
The Solidcom C1 Pro, Hollyland's first-of-its-kind full-duplex wireless intercom headset system featuring dual-mic Environmental Noise Cancellation (ENC) technology, is incredibly lightweight and easy to use. It is a true game changer with built-in ENC, ideal for production teams working in loud environments where exceptional communication clarity is essential. This new-generation headset system features advanced DECT 6.0 technology, a wideband audio range of 150Hz to 7kHz, and a reliable LOS communication range of up to 1,100ft (350m).
Group111
Dual-Mic
ENC
Group110
PTT
Function
Group109
150Hz–7kHz
Wideband Audio
Group108
1,100ft (350m)
Reliable Range
Group106
Ultra-long
Duration
Group105
Increased Portability
& Durability
Group104
Ready Out
of Box
Group103
Backward
Compatibility
Group111
Dual-Mic
ENC
Group110
PTT
Function
Group109
150Hz–7kHz
Wideband Audio
Group108
1,100ft (350m)
Reliable Range
Group107
DECT 6.0
Enhanced Stability
Group106
Ultra-long
Duration
Group105
& Durability
Group104
Ready Out
of Box
Group103
Backward
Compatibility
Group102
A & B Dual
Grouping
Group101
Three-System
Cascaded Connection
Group100
ANNOUNCE
Function
ENC-powered Clear Audio for Efficient Team Coordination
Unparalleled Dual-Mic ENC
The Solidcom C1 Pro boasts unparalleled dual-mic ENC technology that delivers clear sound captured from challenging loud environments. Its directional main mic focuses precisely on the speaker’s voice range, and simultaneously, the omnidirectional secondary mic collects environmental noise from different directions as noise samples. The sound signal is processed with the advanced ENC algorithm, effectively cancelling the environmental noise and delivering crystal-clear sound quality.
Note: The ENC technology functions by removing the environmental noise at the speaker side, so that the listener can hear the speaker’s voice clearly.
Group200 Group200 pe
ENC OFF
ENC ON
150Hz–7kHz Wideband Audio with AEC
The Solidcom C1 Pro intercom system is capable of delivering authentic and clear sound even in the most demanding production environments. Its premium Acoustic Echo Cancellation (AEC) function effectively removes unwanted echo within the 150Hz to 7kHz frequency response range, bringing in more efficient teamwork.
Robust Wind Noise Removal
Troubled by wind noise in outdoor production environments? The Solidcom C1 Pro offers a versatile solution that prevents airflow from directly hitting the mic. With the Y5 felt paper designed for the main mic as the wind filter as well as the microphone cushion, you can enjoy complete peace of mind in production environments where wind noise is a major challenge.
Group400 Group400 pe
Group401
ENC OFF Group403
Wind Speed
3m/s
Wind Noise (dB)
-16.87
Group404
Group402
ENC OFF + Felt Paper Group403
Wind Speed
3m/s
Wind Noise (dB)
-20.76
Group405
Exceptional Simplicity for Efficiency
The Solidcom C1 Pro is ready when you are. The out-of-the-box and ready-to-go features redefine the wireless intercom system category, and its simple form factor design achieves a breadth of intuitive operations. Just switch the headset ON, place it on your head, and then begin talking with your team in a matter of seconds, so that you can focus more on efficient hands-free team collaboration.
Well-marked Nameplates
Group500 Group500 pe
Red: Master headset
Blue: Remote headset
TALK/MUTE Button with the PTT Function
Note:
1. To switch between the TALK and MUTE modes, simply press the TALK/MUTE button. You can also switch between the two modes by rotating the mic boom up or down.
2. To use the PTT function, press and hold the TALK/MUTE button to talk and then release the button to mute yourself.
Group600 new
Group700
Volume Button
+: Volume up
-: Volume down
A & B Button
In a non-hub system, the A button is used for pairing, while the B button does not function.
In a hub-based system, simply press the A or B button to switch to group A or B.
Group800
Group900
Mic Boom
Indicator Light
Indicator light flashes: Not connected Indicator light
flashes quickly: Pairing Red indicator light flashes
twice: Low battery
Group1000 Group1000 pe
Keep Connected Within a 1,100ft (350m) LOS Range
The transceiver built into the Solidcom C1 Pro master headset offers a reliable wireless two-way communication range of up to 1,100ft (350m). Your team can keep connected and move freely across an expansive space at major events, such as church productions, TV & film productions, live performances & events, and more.
Group1100
Uncompromising Security & Stability
The Solidcom C1 Pro offers full support for secure communication by preventing people outside the system from hearing your conversation with its encryption technology.
Reinforced anti-interference capability
With a dual-antenna design scheme for each headset, the Solidcom C1 Pro enables unparalleled interference-free communication stability and clarity with a doubled user capacity on the communication channel.
Group1200
Intercom All Day Long with Rechargeable & Replaceable Batteries
Ultra-low power consumption
20%
reduced
Note:
Each headset comes with a spare lithium battery for convenient field replacement, keeping the system running with minimal downtime.
Group1300
Master headset
6
hours working time
(connection with 3 remote headsets)
Remote headset
10
hours
working time
Time to charge
2.5
hours
Increased Portability & Durability for a Better Experience
The Solidcom C1 Pro headset is crafted using PC-ABS materials, making it incredibly lightweight—a mere 170g (6oz) with the battery included and super compact. The upgraded over-ear leather cushion better fits the human ear structure for added stability and comfort, perfect for anyone who works in challenging environments. Durable on-ear foam cushions are also provided to address different wearing preferences. Simply use them as needed and enjoy the experience of incredible portability and comfort without compromising quality.
Group1400 Group1400 pe
Backward Compatible with the
The Solidcom C1 Pro is perfectly compatible with the entire Solidcom C1 wireless intercom system for increased flexibility and expandability.
Group1500
New Interface on the Hub for More
Professional Applications
The Solidcom C1 Pro hub is designed with a brand-new interface, supporting a more stable wired headset attachment to the hub in more professional applications. The wired headset of the hub-based system also features ENC technology that significantly rejects unwanted background noise and annoying echo.
Group1700
A & B Grouping for Diversified Communication Needs
The Solidcom C1 Pro hub-based intercom system provides more communication options with its A & B grouping function. It offers two communication channels for groups A and B in the team, greatly eliminating the possibility of communication interruption and improving team coordination efficiency.
Group1600
UAC for Direct Calls to Cloud Meetings
The USB Audio Class (UAC) function featured on the hub facilitates joining cloud meetings anytime running on Zoom, Skype, or other meeting programs. Simply connect your personal computer to the hub via its USB interface. This seamlessly brings your on-site and remote teams together, facilitating team interaction and creativity wherever your teams are located.
Group1800
Keep Talking on the Go with Multi-Powering Options
The Solidcom C1 Pro hub supports multiple power supply options, including NP-F battery, V-mount battery, G-mount battery, and DC power.
Group1900
Group1901
Group1902
Note: The Solidcom C1 Pro hub batteries must be purchased separately.
Three-System Cascaded Connection for Greater User Capacity
The Solidcom C1 Pro hub can interconnect different systems to accommodate expanded communication needs. It offers 2- and 4-wire audio input/output interfaces, and up to 3 hub-based systems can be cascaded via an IP network. You can easily daisy-chain different systems as needed on site to meet even more complex operational requirements.
Note: Please keep at least 2 meters between the cascaded devices.
Group2000
Standard RJ45 cable (up to 300m)
ANNOUNCE for Emergencies
The Solidcom C1 Pro hub is designed with a one-button “ANNOUNCE” function for emergencies. By activating this function in an emergency, all headsets in the system are instantly muted, allowing the entire team to only hear the direct instructions or commands from the user of the wired hub headset.
Group2100
Customizable and Expandable for Varying Team Sizes
The Solidcom C1 Pro is available in a variety of non-hub packages for accommodating team sizes ranging from 2 to 8 members. If A & B grouping and the ANNOUNCE function are desired, a hub (including a wired headset) can be easily incorporated into any number of headsets. A hub-based system supports a communication team with up to 9 members.
Note: A master headset cannot be used in a hub-based system.
Group2200 Group2200 pe
Group2201 Group2201 pe
Group2202 Group2202 pe
Group2203 Group2203 pe
Group2204 Group2204 pe
Group2205 Group2205 pe
Group2206 Group2206 pe
Group2207 Group2207 pe
What’s in the Box
inbox100 new
Master & Remote Headsets
Battery
4-Slot Charging Case
8-Slot Charging Case
Microphone Cushion
Over-ear Leather Cushion
On-ear Foam Cushion
DC Adapter
USB-A to Type-C Cable
Storage Case
User Manual
Warranty Card
Hub
0B10 Wired Headset
Remote Headset
High-Gain Antenna
Battery
Microphone Cushion
On-ear Foam Cushion
12V2A DC Adapter
USB-A to USB-C Cable
Storage Case
User Manua
Warranty Card
Parameters
Transmission Range
1,100ft (350m) LOS
Frequency Band
1880-1900 MHz: Europe, South Africa, much of Asia, Hong Kong, Australia,
and New Zealand (10 channels)
1880-1895 MHz: Taiwan (8 channels)
1893-1906 MHz: Japan (J-DECT)
1910-1920 MHz: Brazil (10 channels)
1910-1930 MHz: Much of Latin America excluding Brazil
1920-1930 MHz: USA and Canada
Modulation Mode
GFSK
RX Sensitivity
<-90dBm
Battery Capacity
700mAh(2.66Wh)
Operation Time
Remote headset: >10 hours (ENC ON)
Master headset: >5 hours (ENC ON with 5 remote headsets)
Master headset: >4 hours (ENC ON with 7 remote headsets)
Charging Time
About 2.5 hours
Frequency Response
ENC OFF: 150Hz–7kHz (fluctuation range: ±6dB)
ENC ON: 150Hz–7kHz
Signal-to-Noise Ratio
71±2dB@94dBSPL,1kHz
Distortion
<1%@94dBSPL, 150Hz–7kHz
Microphone Type
Electret
Input SPL
>115dBSPL
Output SPL
94±3dBSPL (@94dBSPL, 1kHz)
ENC
20dB±2
Net Weight
About 170g (6oz) with the battery included for each wireless headset
Temperature Range
0℃ to 45℃ (working condition)
–10℃ to 60℃ (storage condition)
