banner-pc banner-pe
Designed with the expressed needs of customers in mind, Solidcom C1 Pro – Roaming Hub boasts support for up to 20 headsets and 6 groups, seamless roaming, an extensive range of 1,600ft (500m), and backward compatibility, among other powerful functions and features. This innovative solution will definitely empower people across all styles of communication settings, including filmmaking and video production, and take their communication experience to new heights.
sellpoint-1
20-User Connectivity
20-User
Connectivity
sellpoint-2
1,600ft (500m) LOS Range
1,600ft (500m)
LOS Range
sellpoint-3
Seamless Roaming
sellpoint-3
6-Group Talking
sellpoint-3
USB Audio Class
sellpoint-3
App Control
Streamlined Workflow
20-User Effortless Communication.
Solidcom C1 Pro – Roaming Hub alone supports up to 20 headsets without the need for cascading, thus ensuring easy set-up and reducing cable clutter. With this game-changer, the communication needs of many different applications can be easily met.
stream-1 stream-1
40-User Effortless Communication.
When two hubs are cascaded via IP or 4-wire, the system can support up to 40 headsets, accommodating the needs of most large-scale team communication and complex work environments.
stream-1 stream-1
Two Hubs Cascade Connection
twohub
*Use a standard CAT5e or above cable to cascade the two hubs, with a cable length of 300-500ft.
Unobstructed Connection
Seamless Roaming.
The seamless roaming capability of Solidcom C1 Pro – Roaming Hub guarantees effective communication behind walls or complex structures where dropouts tend to happen from time to time, ideal for production team members who need to move freely and wirelessly from one coverage area to another. No matter where your work takes you, enjoy consistent communication.
Effective Talking
Maximum 6 Groups.
Solidcom C1 Pro – Roaming Hub supports 6 groups at most, making it highly useful for professional scenarios that call for communication among multiple function groups such as productions, camera crews, lighting, and many more. You can also assign roles and customize the number for each type of role for better coordination.
effective effective
effective effective
1,600ft (500m)
Long Range Transmission.
With 4 robust omnidirectional fiberglass antennas maintaining stability, Solidcom C1 Pro – Roaming Hub boasts a LOS (line of sight) range of up to 1,600ft (500m), capable of use in large venues or open spaces, giving the ability to immerse yourself in reliable and stable communication.
Group500 Group500 pe
Perfect Integration
Backward Compatibility.
Solidcom C1 Pro – Roaming Hub is perfectly compatible with both Solidcom C1 and Solidcom C1 Pro headsets.
Group600 Group600 pe
Hassle-Free Installation
Enhanced Mounting Flexibility.
Solidcom C1 Pro – Roaming Hub features industry-standard 5/8” and 3/8” mounting holes, which directly enable the attachment of a variety of accessories, such as tripods, light stands, and more, thus assuring hassle-free installation on sites.
Replay
Replay
Online Conversation
Easy Off-Site Communication.
Solidcom C1 Pro – Roaming Hub supports USB Audio Class (UAC), facilitating real-time online communication with off-site personnel. Through a direct USB-C connection to your computer, you can start online conversations without the necessity of sound capture cards.
Group700 Group700 pe
Group800 Group800 pe
Effortless Configuration
App Control.
With the built-in Bluetooth module, Solidcom C1 Pro – Roaming Hub provides users with easy access to modify settings directly from their mobile devices via a specially developed app. Bid farewell to long walks to the hub just for parameter adjustments.
Applications
Group900
Group901
Group902
Group903
Group904
Group905
What’s in the Box
Solidcom Roaming Hub x1
Solidcom Roaming Hub Antenna x4
G-Mount Battery Plate x1 (on the hub)
Solidcom Roaming Hub Hard-shell Carry Case x1
User Manual x1
Warranty Card x1
V-Mount Battery Plate x1 (on the hub)
User Manual x1
Warranty Card x1
Solidcom C1 Pro Wireless Single-Ear Remote Headset x10
Solidcom C1 Pro Battery x20
Solidcom C1 Pro 8-Slot Battery Charging Case x1
Solidcom C1 Pro Over-Ear Earmuff x10
Solidcom C1 Pro On-Ear Earmuff x10
Solidcom Headset Ear Pad x10
Solidcom C1 Pro Mic Cushion x10
Solidcom Headset Sticker x1
12V/2A DC2.1 Power Adapter x1
USB TypeC Cable x1
Solidcom C1 Pro – Roaming Hub20S Hard-shell Carry Case x1
User Manual x1
Warranty Card x1
USB TypeC Cable x1
User Manual x1
Warranty Card x1
Solidcom C1 Pro Wireless Single-Ear Remote Headset x20
Solidcom C1 Pro Battery x40
Solidcom C1 Pro 8-Slot Battery Charging Case x3
Solidcom C1 Pro Over-Ear Earmuff x20
Solidcom C1 Pro On-Ear Earmuff x20
Solidcom Headset Ear Pad x20
Solidcom C1 Pro Mic Cushion x20
12V/2A DC2.1 Power Adapter x3
USB TypeC Cable x1
User Manual x1
Warranty Card x1
USB TypeC Cable x1
User Manual x1
Warranty Card x1
Specifications
LOS Range
1,600ft (500m)
Operating Frequency
1904 – 1919 MHz: China
1880 – 1900 MHz: Europe, South Africa, much of Asia,
Hong Kong SAR, Australia, and New Zealand (10 channels)
1880 – 1895 MHz: Taiwan (8 channels)
1893 – 1906 MHz: Japan (J-DECT)
1910 – 1920 MHz: Brazil (10 channels)
1910 – 1930 MHz: Much of Latin America excluding Brazil.
1920 – 1930 MHz: USA & Canada
Transmit Power
≤ 21 dBm
Bandwidth
1.728 MHz
Modulation Mode
GFSK
Frequency Response
100 Hz – 7 kHz (±3dB) @1 kHz
Receiver Sensitivity
≤ -90 dBm
SNR
> 55dB
Antenna Gain
4 dBi (all directions)
DC Voltage Range
7 – 30V, < 1A@12V
V/G Mount Battery Voltage Range
11 – 30V, < 1A@12V
Power Consumption
< 1A@12V
Dimensions
302mm × 181.52mm × 63.6mm
Weight
1797.5g (63.4oz)
Temperature Range
-10 – 45℃ (working)
-20 – 60℃ (storage)
