Buy
  • Group 1306
    Flexible & Wide
    Compatibility
  • Group 1290
    Smart Sequence
    Learning
  • Group 1288
    Adaptive Frequency
    Hopping
  • Group 1289
    2,600ft (800m)
    Transmission
  • Group 1293
    Up to 16 Channels
    Supported
  • Group 1294
    8-Hour Duration
    Detachable Battery
  • Group 1295
    Incredibly
    Compact & Portable
Wireless Tally System is a highly compatible Tally device with multiple ports and a powerful sequence learning function. With its long battery life and over 2,600ft (800m) transmission range, it provides a stable and prolonged shooting experience. The system utilizes adaptive frequency hopping technology and supports up to 16 Tally channels, significantly enhancing work efficiency.
Group 1543
Powerful, Portable, Adaptable Group 1544
Wide Compatibility
with Various Switchers
Wireless Tally System offers multiple port options, including DB25, RJ45, and USB-C, to support the connection to various switchers.
  • TNC
    Antenna Connector
  • DC
    DC Input
  • Tally (RJ45)
    Tally Input RJ45 Port
  • Control LOOP OUT (RJ45)
    Switcher Loopout RJ45 Port
  • Tally (DB25)
    Tally Input Port (DB25 F)
  • USB-C
    USB-C Port (reserved)
tnc
dc
tally-rj45
control-loop-out
tally-db25
usb-c
port
port
1-3
4-6
  • 01
    TNC
    Antenna Connector
    02
    DC
    DC Input
    03
    Tally (RJ45)
  • 04
    05
    Tally (DB25)
    06
    USB-C
Wireless Tally System is for
Compatible
In future firmware upgrades, Wireless Tally System will be compatible with more brands and models.
Brand Model Cable
brand HS1200 DB25 Male to HDB15 Female
HS1300 DB25 Male to HDB15 Female
HS1500T DB25 Male to HDB15 Female
HS1600T DB25 Male to HDB15 Female
HS2800 DB25 Male to DB25 Male
HS3200 DB25 Male to DB25 Male
HS4000 DB25 Male to DB25 Male
SE500 DB25 Male to HDB15 Female
SE500HD DB25 Male to HDB15 Female
SE650 DB25 Male to HDB15 Female
SE2800 DB25 Male to DB25 Male
SE3200 DB25 Male to DB25 Male
SE4000 DB25 Male to DB25 Male
brand AV-HS6000MC DB25 Male to DB25 Male
AW-HSW10 DB25 Male to DB15 Male
AW-UHS500 DB25 Male to Dual DB15 Male
AV-HS410MC DB25 Male to Dual DB15 Male
brand MCX-500 DB25 Male to DB9 Female
brand ATEM Mini Ethernet Cable
ATEM Mini Pro Ethernet Cable
ATEM Mini Pro ISO Ethernet Cable
ATEM Mini Extreme ISO Ethernet Cable
ATEM SDI Pro ISO Ethernet Cable
ATEM SDI Extreme ISO Ethernet Cable
ATEM Constellation 8K Ethernet Cable
ATEM 1 M/E Constellation HD Ethernet Cable
ATEM Television Studio Pro 4K Ethernet Cable
ATEM 1 M/E Production Studio 8K Ethernet Cable
brand Roland V-60HD DB25 Male to DB25 Male
Roland V-80HD DB25 Male to DB25 Male
Roland V-160HD DB25 Male to DB25 Male
Roland V-600UHD DB25 Male to DB25 Male
Roland V-800HD DB25 Male to Dual HDB15 Male
Roland V-1200HD DB25 Male to DB25 Male
Roland VR-6HD DB25 Male to DB25 Male
Roland VR-120HD DB25 Male to DB25 Male
brand vMix Ethernet Cable
brand DeviceWell HDS7305 DB25 Male to HDB15 Male
Compatible List
Simplify Your Setup
with Sequence Learning
By utilizing the powerful sequence learning function of the system, you can easily connect any switcher that operates with high or low voltage levels to the system using a standard Tally cable, achieving higher switcher compatibility.
brand-a
brand-b
Boost Your Seamless Workflow
Adaptive Frequency Hopping
for Seamless Shooting
With the adaptive frequency hopping feature, this Wireless Tally System can detect the interference in complicated scenarios, and hop to the channel with less interference to ensure stable signal transmission.
Ultra-Long 2,600ft (800m)
Stable Transmission
With a stable transmission capability over a line of sight range of 800 meters, this Wireless Tally System can meet your needs for shooting in long-distance scenarios.
2600ft (800m)
Up to 16 Channels Supported
Wireless Tally Station supports up to 16 channels. This allows for easy expansion or reduction in the number of Tally lights to accommodate projects of varying scales or complexities.
port
port
*The DB25 port supports a maximum of 12 channels of dual-color Tally, while the RJ45 port can support up to 16 channels of dual-color Tally.
Non-stop Shooting
8-Hour Duration Detachable Battery
A single battery provides a life of over 8 hours, surpassing the working duration requirements for most usage scenarios. Even if the Tally device runs low on battery during operation, you can immediately replace it to ensure uninterrupted usage.
Battery
8-Hour Duration
Long-lasting Battery
Compatibility
Compatibility
The batteries are compatible with the Hollyland wireless intercom systems, Solidcom C1 and Solidcom C1 Pro.
Compact & Portable
Extremely lightweight, the Tally lights only weigh 98.5g (with battery).
weigh
size
Packing List
Tally Light x4
Tally Light x4
Tally Station x1
Tally Station x1
Tally Hard-Shell Case x1
DC Power Adapter x2
DC Power Adapter x2
Wireless Tally System Antenna x2
8-slot Charging Base x1
Li-ion Battery Pack 700 x4
USB-A to USB-C Cable x1
Number Stickers x1
Number Stickers x1
Ouick Guide x1
Ouick Guide x1
Warranty Card x1
Warranty Card x1
Compliance Information x1
Tally Light x8
Tally Light x8
Tally Station x1
Tally Station x1
DC Power Adapter x2
DC Power Adapter x2
Li-ion Battery Pack 700 x8
Number Stickers x1
Number Stickers x1
Ouick Guide x1
Ouick Guide x1
Warranty Card x1
Warranty Card x1
Specifications
Transmission Range
Up to 2,600ft (800m) for LOS
Wireless Frequency
2.4 GHz
Modulation Mode
LORA
Receiver Sensitivity
<-115 dBm
Transmission Delay
< 150ms
Battery Life
> 8 hours
Dimensions (L*W*H)
77.8 × 50.5 × 37.4mm
Weight
About 85g
Temperature
Working: 32℉ to 113℉ (0℃ to 45℃ )
Storage: 14℉ to 140℉ (-10℃ to 60℃ )
Transmission Range
Wireless Frequency
2.4 GHz
Modulation Mode
LORA
<-115 dBm
Transmission Delay
< 150ms
Battery Life
> 8 hours
Dimensions (L*W*H)
142.5 × 232.8 × 50.1mm
Weight
About 1,262g
Temperature
